I was wondering if anyone here knows if there is any library in micropython for the Raspberry Pi Pico to use a DAC (PCM5102). I want to output sound from a wavetable using the DAC.
So far I have not found any code in micropython to do this, however there is a code for circuitpython that works well:
import array
import math
import audiocore
import board
import audiobusio
sample_rate = 8000
tone_volume = .1 # Increase or decrease this to adjust the volume of the tone.
frequency = 440 # Set this to the Hz of the tone you want to generate.
length = sample_rate // frequency # One frequency period
sine_wave = array.array("H", [0] * length)
for i in range(length):
sine_wave[i] = int((math.sin(math.pi * 2 * frequency * i / sample_rate) *
tone_volume + 1) * (2 ** 15 - 1))
audio = audiobusio.I2SOut(board.GP16, board.GP17, board.GP18)
sine_wave_sample = audiocore.RawSample(sine_wave, sample_rate=sample_rate)
audio.play(sine_wave_sample, loop=True)
time.sleep(1)
audio.stop()
time.sleep(1)
