Range/roaming explicit AP selection? I was looking at mqtt_as module and examples, and range_ex.py script, that looks for the strongest RSSI signal, but as far as I can tell, no explicit binding is done, the typical connect is (trusted) to find the strongest WiFI signal.
But I also noticed that network.WLAN (at least some implementations, has parameter to bind to a specific BSSID? If I am already connected to the strongest AP, I don't want to disconnect for no reason, otherwise take the hit and reconnect to the 'better' AP. How can I do this? Can I even do this? A selective reconnect that is.
Connecting seems straight forward... given WLAN.connect(ssid=None, key=None, *, bssid=None). Scan to find the strongest seems straight forward the range_ex.py script already illustrates this via RSSI result.
So the hang up is <interface>.confg('bssid') does not seem to be an option? Can I query network.WLAN for the current BSSID? I don't think so? Did I miss it?
>>> theInterface.config('bssid')
ValueError: unknown config param
At least on my Pico W no joy.
This would really be a great benefit for say publishing under MQTT, where is the publish fails, then checking for a better AP and selective reconnect, then republish would be a nice approach, no? Oh and given mqtt_as has a publish timeout example that might be part of the scenario as well of course.
Re: Range/roaming explicit AP selection?
Bump! No one?
