Cross compiling to arm-linux
jjlong
Post by jjlong » Wed Mar 16, 2016 7:24 am
I'm trying to cross-compile to use MicroPython on an embedded linux device. Following the instructions on github, on an ubuntu machine i've tried the following:
 git submodule update --init
 make CROSS_COMPILE=arm-linux-gnueabihf- deplibs
This appears to work, but when I then run:
it fails with the following message:
modffi.c:32:17: fatal error: ffi.h: No such file or directory
#include <ffi.h>
compilation terminated.
When I inspect lib/libffi/build_dir/include, the file 'ffi.h' is there. Any ideas? Are there additional steps required to cross-compile?
Re: Cross compiling to arm-linux
Post by dhylands » Wed Mar 16, 2016 7:29 am
This is looking for ffi.h typically in /usr/include someplace. You either need to install libffi-dev or disable ffi by setting building with
make MICROPY_PY_FFI=0
jjlong
Post by jjlong » Wed Mar 16, 2016 8:33 am
I do have libffi installed, but I would have thought it shouldn't matter if I am trying to cross-compile for a different target, and using make deplibs to try to satisfy the dependencies. For the finish, referencing https://github.com/micropython/micropython/issues/253, I ran this command which solved the issue:
PKG_CONFIG_PATH=~/micropython/lib/libffi/build_dir/ make CROSS_COMPILE=arm-linux-gnueabihf- MICROPY_PY_FFI=1
Post by dhylands » Wed Mar 16, 2016 4:31 pm
If you're cross compiling then you need the cross-compiled libffi installed as well.
So if you on an x86 machine, and have x86 libffi, that can only be used for x86 targets.
If you're cross compiling for arm, then you need the arm libffi installed in a place that the cross compiler will find it.
jgriessen
Post by jgriessen » Mon Jun 27, 2016 12:58 am
Hello Dave, I've been looking things up in the docs getting ready to use my nucleo-F401RE board and later to develop some new stmhal platforms. I came across your write-up https://github.com/micropython/micropyt ... g-st-flash by googling. It is not easy to find any link to it from the main wiki. I'd like to get wiki writing privileges and help. I can write up my first time experiences and it will help others get to it quickly even on a weekend when the forum is quiet. There is not much about development mentioned from the micropython.org docs -- either developing micropython, or using micropython to develop apps on an ARM micro that is not a pyboard. The github page section called "The STM version" is inadequate for a beginner to get results with because of partly defined terms like: To build: $ cd stmhal -- from where though? It is not step by step -- it assumes you've got helpers on the forum to get past the parts that are not written.
So I'll make myself available to write some of this unwritten documentation. John Griessen
John Griessen blog.kitmatic.com
Post by dhylands » Mon Jun 27, 2016 3:51 am
I think you just need a github account to edit the wiki.
SUBBU3881
Post by SUBBU3881 » Mon Apr 09, 2018 11:45 am
Nice discussion. I am also trying to port micropython on to Beagle-Bone Black Linux board. I am facing <b> ffi.h not found<b> issue.
Will MICROPY_PY_FFI=0 solve the issue.?
does Building micropython on to Beagle-Bone not needed MICROPY_PY_FFI.?
Please respond as soon as possible.
Thanks and Regards,
Siva Prakash Reddy
Post by dhylands » Mon Apr 09, 2018 5:27 pm
It isn't really a case of whether MicroPython needs FFI, its a case of whether your code calls any functions which need it.
Many of the functions in micropython-lib call into libc or other shared libraries using FFI. If you don't need to call those functions then you don't need FFI.
