Unreliable Operation: FTP, Telnet, Power, ...
Re: Unreliable Operation: FTP, Telnet, Power, ...
Yes, i also found that when the FTP client does not observe the constraints (e.g. trying TLS or opening a second connection), the whole system seems to freeze. I tested this by running a loop in a Telnet window, which suddenly stopped when the FTP client opened a second connection.
- danicampora
Yes I am aware that other clients can make it crash. I'll work on that soon.
I found out how to see what commands are being sent by lftp, and it looks like this:
At this pooint WiPy probably crashes, as it becomes unresponsive and the heartbeat LED stops blinking. I can totally understand that TLS is not supported, but I'm quite sure it shouldn't cause the board to crash.
UPDATE: "set ftp:ssl-allow no" makes it work just fine, so that must be it.
---- Connecting to 192.168.0.17 (192.168.0.17) port 21
<--- 220 Micropython FTP Server
---> FEAT
<--- 332
---> AUTH TLS
<--- 332
---> USER micro
- danicampora
Thanks deshipu!
I agree! I need to investigate why it crashes when a secure connection is attempted.I can totally understand that TLS is not supported, but I'm quite sure it shouldn't cause the board to crash.
- danicampora
Thanks, that's a good idea.I think what will help future users to avoid my problems is adding a one-page instruction sheet to the box that
Hallo, same Problem here:
Hallo, just received wipy from Kickstarter.
MicroPython v1.5-1-ge954604 on 2015-10-21; WiPy with CC3200
MAC:
Raw Yosemite FTP -> NO.
Forklift -> NO.
YummyFTP 1.1 MAC APP STORE -> YES. See Pic attached.
MAC:
Forklift -> NO.
- Bildschirmfoto 2015-10-23 um 20.37.18.png (224.68 KiB) Viewed 9968 times
- danicampora
Hi all,
The crash issues when a secured or multiple FTP connections are attempted should be fixed now. Damien has setup a daily build of the WiPy here: http://micropython.org/download/ , feel free to test it and let us know if the FTP problems are gone. Thanks!
Cheers,
Daniel
Cheers,
Daniel
I have flashed, it works! Thank you, Daniel!danicampora wrote:Hi all,
Cheers,
Daniel
$ lftp 192.168.6.111
lftp 192.168.6.111:~> user micro python
lftp micro@192.168.6.111:~> ls
drw-rw-r-- 1 root root 0 Jan 1 2015 flash
lftp micro@192.168.6.111:/> mirror -R flash flash
Total: 1 directory, 10 files, 0 symlinks
New: 1 file, 0 symlinks
To be removed: 2 directories, 0 files, 0 symlinks
2 errors detected
PYBv1.0, WiPy
- danicampora
Hi xyb!
Great
Thanks for the feedback!
Cheers,
Daniel
Great
Cheers,
Daniel
- danicampora
What's that about? Any idea what are the errors that lftp refers to?2 errors detected
