Using local time with Pico W
Re: Using local time with Pico W
Post by pythoncoder » Thu Jul 28, 2022 8:41 am
Very useful. I'd missed that.
Elmidea
Post by Elmidea » Tue Aug 02, 2022 9:31 am
Should I change anything to the micropython-samples/ntptime/ntptime.py code now that the datetime with timezone support was added to the micropython-lib ?
Thank you
Elmidea
Post by Elmidea » Tue Aug 02, 2022 4:35 pm
I think I have found a way to make it work, but I keep getting this error (not every time):
OverflowError: overflow converting long int to machine word
I'm stuck on that, even if I try to reduce the length it doesnt seem to change the issue
Whenever I dont get overflow I get this error:
OSError: [Errno 110] ETIMEDOUT
Which indicates the ntp server doesnt respond in time right? I tried to change the wait from 1 to 10, same thing, and also other npr server adresses, same thing again...
It only works like 1 time out of 10 for some reason, no change in the code, just soft reset of the pico W.
Thanks for your help
p_j
Post by p_j » Wed Aug 03, 2022 12:29 am
Can you post your code?
Elmidea
Post by Elmidea » Wed Aug 03, 2022 7:38 am
Yes here it is, it works like 1 time out of 20 this morning... no idea why, wifi seems solid, wlan status is ok:
main.py :
time.localtime(ntptime.time() + 946684800)
(2022, 7, 16, 17, 25, 50, 5, 197)
ntptime.py :
    import usocket as socket
except:
    import socket
    import ustruct as struct
except:
    import struct
# (date(2000, 1, 1) - date(1900, 1, 1)).days * 24*60*60
NTP_DELTA = 946684800
# The NTP host can be configured at runtime by doing: ntptime.host = 'myhost.org'
host = "0.fr.pool.ntp.org"
def time():
    NTP_QUERY = bytearray(48)
    NTP_QUERY[0] = 0x1B
    addr = socket.getaddrinfo(host, 123)[0][-1]
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
        s.settimeout(1)
        res = s.sendto(NTP_QUERY, addr)
        msg = s.recv(48)
    finally:
        s.close()
    val = struct.unpack("!I", msg[40:44])[0]
    return val - NTP_DELTA
# There's currently no timezone support in MicroPython, and the RTC is set in UTC time.
def settime():
    t = time()
    import utime
    tm = utime.gmtime(t)
    machine.RTC().datetime((tm[0], tm[1], tm[2], tm[6] + 1, tm[3], tm[4], tm[5], 0))
p_j
Post by p_j » Wed Aug 03, 2022 11:18 am
main.py :
ntptime.py :
except:
    import socket
except:
    import struct
def time():
    NTP_QUERY[0] = 0x1B
        s.settimeout(1)
        msg = s.recv(48)
    finally:
        s.close()
def settime():
    t = time()
    import utime
Strange, what is the error?
Post by pythoncoder » Fri Aug 05, 2022 11:03 am
The ntptime function has a short timeout period of one second (for obvious reasons). Sometimes timeouts occur and the function returns a ridiculous result. See my solution which fixes this and other problems. My version returns 0 on error and the caller should check for this.
Hasenradball
Post by Hasenradball » Tue Mar 28, 2023 7:45 am
Hi Together,
I would remark that this description in the Doc is a little bit missleading.
Because on the Pico W the RTC works with the epoch since 1970.
Maybe a small redesign of this description would be perfect, my opinion.
A other point is that I want to aks what the actual status is about:
time.gmtime()
time.localtime()
Is there actually a Timezone information available in micropython?
If not Iam right that these two functions leads to the same result in time structure?
Frank
