ESP32 maximum PWM frequency
loboris
Re: ESP32 maximum PWM frequency
Post by loboris » Wed Jan 10, 2018 8:46 am
OutoftheBOTS_ wrote:
Tue Jan 09, 2018 10:40 pm
@laboris can you post a link to the docs please :)
Sorry, I was quite bussy, I'll try to finish the documentation later today. I will apear on Wiki pages.
mattyt
Post by mattyt » Tue Jan 30, 2018 10:13 am
Just to close the loop, I just noticed that the PWM wiki page is online. Thanks @loboris!
rdagger
Post by rdagger » Tue Jan 30, 2018 6:39 pm
@laboris Would it be possible to add a feature so you could programmatically invert or offset the duty cycle of some of the channels on a timer?
PWM inverted.png (4.61 KiB) Viewed 12106 times
loboris
Post by loboris » Tue Jan 30, 2018 7:34 pm
@laboris Would it be possible to add a feature so you could programmatically invert or offset the duty cycle of some of the channels on a timer?PWM inverted.png
All PWM channels using the same timer have the same frequency and phase.
PWM channel started with different timer will have some random offset depending on time when the timer was started.
It could be possible to synchronize two PWMs, each using a different timer, in such way that one is started at the known time after the other.
That time would be the phase offset between channels.
If that time is half the timer period and the channels period and duty cycles are the same, the PWM's outputs would be inverted.
I'll test it and add that option if it works as expected.
rdagger
Post by rdagger » Tue Jan 30, 2018 10:19 pm
Thanks, that would be very helpful.
mosi
Post by mosi » Thu Mar 15, 2018 8:52 am
Hi, lobo, tremendous work!
Any ideas on how to synchronize two PWMs?
I have seen an option:
#define MCPWM_EN_SYNC 0 //Make this 1 to test sync submodule of mcpwm, sync timer signals
in ESP32-IDF
examples/peripherals/mcpwm/mcpwm_basic_config/main/mcpwm_basic_config_example.c
Idea 1) STM32 module in micropython exposes underlying hardware registers. Reading and writing those registers allows for pretty comfortable control of timers/PWM pins. However, the only option to start two PWM pins with predefined phase shift is through @asm_thumb code. This seems not to be available in ESP32 micropython. Is inline C code possible?
Idea 2) writing my own C code for starting two PWM channels on two given Pins and exposing the function to micropython
Which do you think leads to faster results?
Tried to implement @micropython.asm_xtensa decorator for ESP32, but it fails with CPU crash.
What is the status of the inline assembler for the new ESP32 dual core processors?
Roberthh wrote:
Mon Jan 15, 2018 9:13 pm
https://github.com/micropython/micropyt ... d2db3ff4a3
def do_loop():
    movi(a2, 0x60000300) # GPIO Base address
    movi(a5, 0x10) # set/clear bit 4
    movi(a3, 10) # loop
thalesmaoa
Post by thalesmaoa » Sun Mar 29, 2020 8:44 pm
I know that this is an old post, but I want to know if there are any news. I mean, I'm trying to generate Three-phase PWM with complementary and dead time. Can't find a way to do that with Micropython.
OlivierLenoir
Post by OlivierLenoir » Tue Mar 31, 2020 5:38 am
Have a look at post viewtopic.php?f=2&t=7774&start=10 about MicroPython and Power Electronics - Electrical machine control. It may answer part of your questions.
