upip micropython-os do no work properly
Re: upip micropython-os do no work properly
Post by Roberthh » Fri Jun 21, 2019 6:26 am
Now the final version of this itsy-bitsy thing as a general remove:
def rmtree(d):  # Remove file or tree
        if os.stat(d)[0] == 16384:  # Dir
            for f in os.ilistdir(d):
                rmtree("/".join((d, f[0])))  # File or Dir
            os.rmdir(d)
        else:  # File
            os.remove(d)
    except:
        print("rm of '%s' failed" % d)
Er, rmtree do no work properly
Post by pythoncoder » Fri Jun 21, 2019 7:03 pm
This last version won't remove a directory tree which is populated with files. I think the problem is the path in the line
            os.remove(d)
Post by Roberthh » Fri Jun 21, 2019 7:59 pm
Cannot confirm. That was one of my test cases:
test/
   a
   b
   c
   test/
        a
        b
os.remove(d) is meant for files. If will fail if the file is not removable of if it is not a file, which both does not happen on pyboard, esp32, esp8266.
Edit: With Linux you get trouble because it does not exclude '.' and '..' dirs
Edit 2: So it should be then:
def rm(d):  # Remove file or tree
                if f[0] != '.' and f[0] != '..':
                    rm("/".join((d, f[0])))  # File or Dir
            os.rmdir(d)
        else:  # File
            os.remove(d)
    except:
Post by Roberthh » Sat Jun 22, 2019 6:12 am
@pythoncoder: It's hard to kill that little fly. The problem you found is caused by stat not returning 16384 for a directory on linux. SO the code has to be changed a litte bit again:
        if os.stat(d)[0] & 0x4000:  # Dir
            os.rmdir(d)
        else:  # File
            os.remove(d)
    except:
