I2C LCD screen with Raspberry Pi Pico
emartti
Re: I2C LCD screen with Raspberry Pi Pico
Post by emartti » Fri Feb 12, 2021 10:05 pm
Hello, could I get some help please?
I'm trying to get a crowtail ic2 lcd to work on the pico, it has the MCP23008 module, so pyb_i2c_adafruit_lcd.py and pyb_i2c_adafruit_lcd_test.py should work for me right?
I tried to convert it to pico friendly from pyb, and I get no errors on running it, but the lcd doesn't seem to recieve any commands, it's not backlit but the top row is full. I tested the esp8266 files just in case, but didn't seem to work either. I've used the lcd on arduino before, so there shouldn't be any hardware issues.
I'm not sure if I have the i2c commands correct, I tried to copy from them from the esp8266 files. I would appreciate pointing out the errors.
Here's a link my code: https://github.com/EMartti/crowtail-i2c ... /tree/main
Thank you
Post by dhylands » Fri Feb 12, 2021 11:10 pm
Is it the adafruit backback? https://www.adafruit.com/product/292 Or just a backpack that uses the 23008?
The 23008 is just an I2C GPIO expander, so the code would only work as-is if your 23008 is wired up to the LCD in exactly the same manner as the adafruit one.
emartti
Post by emartti » Sun Feb 21, 2021 6:37 pm
I got it to work in the end, seemed that I was sending bytes in the wrong format, for example if I wanted to send byte I had to write it as bytearray([byte]).
The code is here if someone is interested: https://github.com/EMartti/rasperry_pi_ ... n/1602_LCD
Thanks for the original files I would have been lost without them :D
Post by dhylands » Tue Feb 23, 2021 9:15 pm
I created the following 2 files:
https://github.com/dhylands/python_lcd/ ... i2c_lcd.py
https://github.com/dhylands/python_lcd/ ... cd_test.py
which I tested on my RPi Pico using a SparkFun voltage converter: https://www.sparkfun.com/products/12009
