HX711 - which lib should I use?
Re: HX711 - which lib should I use?
Post by Roberthh » Thu Aug 04, 2022 2:28 pm
What is in line 7?
Post by Roberthh » Thu Aug 04, 2022 3:13 pm
That line is ok. Reload the library to the device.
likith1268
Post by likith1268 » Thu Aug 04, 2022 3:20 pm
still not working, is there any problem in pico??
Post by Roberthh » Thu Aug 04, 2022 3:32 pm
On you previous picture with the connections of the hx711 board, Vcc is connected to GND. And the last code snippet still does not match the connections picture.
Post by Roberthh » Thu Aug 04, 2022 3:40 pm
What is not working. Do you get the error message or no results?
It's working here with my pico.
likith1268
Post by likith1268 » Thu Aug 04, 2022 4:21 pm
hello there,
This is the schematic diagram for the load cell with pico.
this could give you a clear understanding of the connections.
I'm keeping the code as well for your reference.
from hx711_gpio import HX711
pin_OUT = Pin(12, Pin.IN, pull=Pin.PULL_DOWN)
pin_SCK = Pin(13, Pin.OUT)
hx711 = HX711(pin_SCK, pin_OUT)
hx711.tare()
value = hx711.read()
value = hx711.get_value()
#this is the hx711_gpio file.
from machine import enable_irq, disable_irq, idle
class HX711:
    def __init__(self, pd_sck, dout, gain=128):
        self.pSCK = pd_sck
        self.pOUT = dout
        self.pSCK.value(False)
        self.GAIN = 0
        self.OFFSET = 0
        self.SCALE = 1
        self.time_constant = 0.25
        self.filtered = 0
        self.set_gain(gain);
    def set_gain(self, gain):
        if gain is 128:
            self.GAIN = 1
        elif gain is 64:
            self.GAIN = 3
        elif gain is 32:
            self.GAIN = 2
        self.read()
        self.filtered = self.read()
    def is_ready(self):
        return self.pOUT() == 0
    def read(self):
        # wait for the device being ready
        for _ in range(500):
            if self.pOUT() == 0:
                break
            time.sleep_ms(1)
            raise OSError("Sensor does not respond")
        # shift in data, and gain & channel info
        result = 0
        for j in range(24 + self.GAIN):
            state = disable_irq()
            self.pSCK(True)
            self.pSCK(False)
            enable_irq(state)
            result = (result << 1) | self.pOUT()
        # shift back the extra bits
        result >>= self.GAIN
        # check sign
        if result > 0x7fffff:
            result -= 0x1000000
        return result
    def read_average(self, times=3):
        sum = 0
        for i in range(times):
            sum += self.read()
        return sum / times
    def read_lowpass(self):
        self.filtered += self.time_constant * (self.read() - self.filtered)
        return self.filtered
    def get_value(self):
        return self.read_lowpass() - self.OFFSET
    def get_units(self):
        return self.get_value() / self.SCALE
    def tare(self, times=15):
        self.set_offset(self.read_average(times))
    def set_scale(self, scale):
        self.SCALE = scale
    def set_offset(self, offset):
        self.OFFSET = offset
    def set_time_constant(self, time_constant = None):
        if time_constant is None:
            return self.time_constant
        elif 0 < time_constant < 1.0:
            self.time_constant = time_constant
    def power_down(self):
        self.pSCK.value(True)
    def power_up(self):
    def is_ready(self):
    def read(self):
                break
            time.sleep_ms(1)
        result = 0
            self.pSCK(True)
            self.pSCK(False)
            enable_irq(state)
        # check sign
            result -= 0x1000000
        return result
        sum = 0
            sum += self.read()
        return sum / times
        self.SCALE = scale
    def power_up(self):
Screenshot 2022-08-04 171652.png (93.36 KiB) Viewed 10203 times
Post by Roberthh » Thu Aug 04, 2022 4:39 pm
Just to repeat myself: the schematic diagram shows, that you connected the hx711 to GPIO18 and 19. Therefore, the Pin definitions must be:
pin_OUT = Pin(18, Pin.IN, pull=Pin.PULL_DOWN)
pin_SCK = Pin(19, Pin.OUT)
likith1268
Post by likith1268 » Mon Aug 08, 2022 9:05 am
yes, thanks for your reply.
I have changed the pin connection in the code and when i am trying to calibrate it's not working
when i am running the example_rp2_test.py file , it giving me all zero's
and when i am running scale.py file, it gives me a error saying type object 'SPI' has no attribute 'MASTER'
i am attaching the files below, please look at it.
Post by Roberthh » Mon Aug 08, 2022 9:40 am
You should read new values in the 'while True' loop, for instance with:
Otherwise it will print always the same number. And you cannot use the SPI variant of the driver without changing it. It was made for the Pycom variant of a ESP32 based MicroPython.
