Teensy 4.0 & 4.1
Re: Teensy 4.0 & 4.1
The Teensy 4.x builds listed here https://micropython.org/download/all/ are hex files. Look down the page for files starting with the string "TEENSY".
@RobH I ran the pystone test on a MIMXRT1050_EVKB board. The i.MX 1052 MCU on that board has the same core as the Teensy boards, with less RAM: But the Flash chip on the board is different. It's a so-called Hyperflash device. Pystone test: ~4900.
The MIMXRT1050 board is also equipped with a 32MB SDRAM chip. If I use that one for the Python heap, the Pystone result is ~5700.
So I assume that most of the speed degradation we have seen on the Teensy board is related to the flash chip and the increasing cache misses, as the firmware size increases. The Hyperflash runs at higher speed and 8 bit bus width. And so cache misses do not hurt that much.
@Roberthh: Thanks for reporting! Nice to have some comparison material!
I continued running the pystone program on newer firmware versions. The fastest I found was 1.16-98: 3810. Since then it went gradually down to about 3250 for 1.16-194. There seems no relation with the code size: it hardly grew.
I received the MIMXRT1170-EVK a bit earlier than expected. At 1Ghz, it is rated more than twice the CoreMark of the Teensy 4.0/4.1. Wonder how difficult it would be to add to the list of supported Teensy processors for MicroPython.
I have to look for the differences between the boards. At a first glance, it seems that is uses the QSPI chip by default. I have to look into the data sheets and schematics for further details, but you may be able to run a MIMXRT1050_EVK (NOT EVKB!) build. That will not provide a lot of features. And especially features like WiFi are not supported. Lacking a board, I cannot test it. And It's unlikely that I will purchase a board just for verification of a port.
You could start adding the board to the repository, by adding the respecitve files for the MCU in the mimxrt/boards directory, which is however a lot of work.
Maybe I should lurk around here a bit more often in the future. Now I know where @Roberthh get‘s all his great insights into the MicroPython community from
The biggest hurdle I see for (sup)porting MIMXRT117x is upgrading the submodule with the NXP libraries. We have discussed about this and I hope we will find a solution which does not create too much of an overhead. The second interesting question for me is how we would like to incorporate the CM4 controller.
@RobH the SDCard support is currently in review. I have to thank @Roberthh again for his support. I am quite sure that it is working stable now but more test exposure especially in real life scenarios is always appreciated.
https://github.com/micropython/micropython/pull/7608
I just built and deployed the latest v1.16 version of Micropython to a Teensy4.0.
I2C seems to be working.
I can do i2c.scan() and detect all devices on the bus.
Problem: Does not find libraries in /lib. I had to put them in the root.
8-Dale
# Import all board pins.
from machine import SoftI2C, Pin
TP_SDA = Pin(18)
TP_SCL = Pin(19)
# Create the I2C interface.
i2c = SoftI2C(sda=TP_SDA, scl=TP_SCL, freq=400000)
print()
print("Simple I2C bus scanner")
print()
#while not i2c.try_lock():
# pass
scan = i2c.scan()
if scan:
print("Devices on the I2C bus:")
for addr in scan:
print("\tDecimal: {0:3d}, Hex: {1}".format(addr, hex(addr)))
print("There are no devices on the I2C bus")
print()
8-Dale
You can alway add lib to sys.path in your main.py.
import sys
sys.path.append("/lib")
Pre-Built versions are available at the Micropython web site under the "all" link: https://micropython.org/download/all/
At my or alphaFred's repository there are a few branches for features not yet merged. see:
https://github.com/robert-hh/micropython and https://github.com/alphaFred/micropython.
import sys
