Help me build micropython esp32!
Grumpy_Pig_Skin
Post by Grumpy_Pig_Skin » Tue Mar 09, 2021 12:29 am
Can someone please help me/build for me a version of micropython for esp32.
I cannot for the life of me get the esp-idf toolchain to work and build properly in linux.
The git repository is here:
https://github.com/bskp/micropython_esp ... orts/esp32
if someone can please help me I'm on the verge of a mental breakdown getting this thing to work.
Thankyou in advance.
Ollie :)
mattyt
Re: Help me build micropython esp32!
Post by mattyt » Tue Mar 09, 2021 2:47 am
Please submit console output as to where your failure has occurred so we can help diagnose the problem.
It's worth noting that the fork you're using is pre-v1.14 where there was a change in the ESP32 build process (to use CMake). These changes simplified the build process, so you may find it beneficial to rebase the fork against upstream master to take advantage of these improvements.
In any case though, post your output and we'll try to help.
Grumpy_Pig_Skin
Post by Grumpy_Pig_Skin » Tue Mar 09, 2021 12:40 pm
Thanks for the response.
Here is the terminal output from VS Code.
It might be worth noting that to get this started I included the CMakeList.txt from the MicroPython master repos and also the "board" folder from there. otherwise, it wouldn't start the compile at all.
terminal failure.PNG (70.02 KiB) Viewed 2885 times
stijn
Post by stijn » Wed Mar 10, 2021 7:16 am
Just a tip: pretty much every terminal application out there suports copying its text, which is much easier for you to paste here, and much easiers for others to read/handle.
Post by jimmo » Thu Mar 11, 2021 5:07 am
Can you explain more about what you mean?
I don't know how well this process has been tested on Windows.
Can you post the exact commands you ran (before moving any files) and the error output?
