On weekend V1.1.0 pico-sdk was published:
https://www.raspberrypi.org/forums/view ... 2#p1831643
It contains new features, the one I am interested in is baudrate switch entering bootsel mode.
If micropython/lib/pico-sdk would be updated before creating daily build
http://micropython.org/download/rp2-pico/
my flash tool would immediately allow to flash .uf2 over Micropython, as well as to reboot MicroPython as if "machine.reset()" would have been executed (without pressing any switches):
https://www.raspberrypi.org/forums/view ... 9#p1833379
When will daily Pico Micropython build switch to use new V1.1.0 pico-sdk?
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
webrepl_client.py
Re: When will daily Pico Micropython build switch to use new V1.1.0 pico-sdk?
I created github issue:
https://github.com/micropython/micropython/issues/7016
webrepl_client.py
webrepl_client.py
