Nucleo F429ZI DAC/ADC
mpython
Post by mpython » Sun Apr 04, 2021 9:22 pm
Why isn't possible to run ADC on some pins in the yellow ring on the picture, but different pins yes?
In the datasheet, it should work.
Is it possible to repair it in firmware?
#F3=pyb.ADC('PF3') #A3
#F5=pyb.ADC('PF5') #A4
#F10=pyb.ADC('PF10')#A5
  File "<stdin>", line 18, in <module>
ValueError: pin F3 does not have ADC capabilities
And why the pyb library does not contain DAC?
Thank you for your responses.
mpython
Re: Nucleo F429ZI DAC/ADC
Post by mpython » Fri Apr 23, 2021 6:26 am
why isn't implemented PWM in the machine library for nucleo f429zi?
Thank you for your response.
rpr
Post by rpr » Sat Apr 24, 2021 4:06 am
I was able to get the DAC to work by adding the following line
#define MICROPY_HW_ENABLE_DAC (1)
to the end of
ports/stm32/boards/NUCLEO_F429ZI/mpconfigboard.h
and recompiling the micropython firmware.
