Is passing 'self' to another class possible
mc2software
Post by mc2software » Sat Apr 17, 2021 8:30 pm
I have a class and I want to pass the class as an argument to a function in another class. I'm thinking I can't do this because I have not instantiated an object of either class.
# constants
PLAYER1 = 0
PLAYER2 = 1
RACKS = 2
BALLSREMAINING = 3
ADD = 1
SUBTRACT = 2
INITALIZE = 0
LOW = 0
HIGH = 1
class Score:
    def __init__(self, display, buttonLeds, numDisplays, numDigits):
        display is the object that will display the calculations
        Constructor:
        self.numPlayers = 2
        self.numButtons = self.numPlayers * 2
        self.playerScore = []
        self.playerUp = 0
        self.numRacks = 0
        self.ballsOnTable = 15
        self.ballsOnFoul = 0
        self.buttonLeds = buttonLeds
        self.ledDisplay = [numDisplays]
        self.ledDigit = [numDigits]
        self.decimalPoint = False
        self.quickStart = False
        for i in range(self.numPlayers):
            self.playerScore.append(0)
    def updateDisplay(self, display):
        if isinstance(mc2Display, mc2Max7219.SevenSegment):
            LedDisplay.updateDisplay(self, display)
            LcdDisplay.updateDisplay(self, display)
In the above class I want to call a function in the following class:
class LedDisplay:
    def __init__(self):
        This handles the display of the score. We keep them separate so that, if we move to LCD from LED display,
            the Display and Score classes can potentially be the same or just swapped
        self.displayText = '000000 00 00'   #default display pattern
    def updateDisplay(self, display, score):
        #display is a mc2Max7219 object
        numDisplays = 4
        digits = []
        for i in range(numDisplays):
            digits.append(' ')
        digits[0] = "{:03d}".format(score.playerScore[0])
        digits[1] = "{:03d}".format(score.playerScore[1])
        if self.ballsOnTable < 0:
            digits[2] = "{:03d}".format(score.ballsOnTable)
            digits[2] = " {:02d}".format(score.ballsOnTable)
        if self.numRacks < 10:
            digits[3] = "  {:01d}".format(score.numRacks)
            digits[3] = " {:02d}".format(score.numRacks)
        display.displayText(digits[0] + digits[1] + digits[2] + digits[3])
I'm trying to separate the programming logic from the UI. As I write this post, I'm thinking I need to do this from yet another class or in the main.py.
Re: Is passing 'self' to another class possible
Post by pythoncoder » Sun Apr 18, 2021 12:26 pm
Most applications involving displays instantiate the display early in the code's execution. That instance - typically a global singleton - is then available for use by any other object.
