I am having a problem with the web server.
Each time the server is restarted, I have the error [Errno 112] EADDRINUSE on the line s.bind (('', 80))
I have to wait about 2 minutes to be able to restart it without problem.
I am in micropython v1.15 with an ESP32.
Can you solve my problem?
Thank you.
Re: [Errno 112] EADDRINUSE
It would be best if you posted the code your running. You probably are not deiniting the server/socket properly. Socket might still be hanging around somewhere.
This is part of the code that I have lightened. Socket is not used anywhere other than there.
For the output variable, it contains my html page.
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('', 80))
s.listen(5)
r, w, err = select.select((s,), (), (), 1)
if r:
for readable in r:
if gc.mem_free() < 102000:
gc.collect()
client, client_addr = s.accept()
client.settimeout(4.0)
print("Connecté avec le client", client_addr)
client_handler(client)
except OSError as e:
pass
def client_handler(client_obj):
request = client_obj.recv(1024)
request = str(request)
client_obj.settimeout(None)
print('Content = %s' % request)
output = my page html
response = output
client_obj.send('HTTP/1.1 200 OK\n')
client_obj.send('Content-Type: text/html\n')
client_obj.send('Connection: close\n\n')
client_obj.sendall(response)
client_obj.close()
client_obj.close()
print('Connection closed')
Try adding:
before bind().
Explained here:
https://stackoverflow.com/questions/322 ... tion-linux
I don't know for sure if that's your problem, but it sounds like it is based on the condition eventually timing out. I haven't confirmed this by digging into it at a lower level to see if this is exactly the case.
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
Explained here:
Thank you so much. It seems to work with the line you made me add.
