Nucleo H743ZI2 USB connect
mpython
Post by mpython » Mon Jul 26, 2021 8:05 pm
Hello, I have a problem with connecting to H743ZI2 via USB after deploying the micropython firmware.
The error from thonny:
Thank you for your advice.
Re: Nucleo H743ZI2 USB connect
Post by jimmo » Wed Aug 04, 2021 5:26 am
Which firmware (where did you get it from, what is the filename). How did you flash/deploy it? What board are you using (is it the NUCLEO-H743ZI). How are you connected to the REPL?
nedkonz
Post by nedkonz » Tue Aug 24, 2021 10:48 pm
There are slight differences between the H743ZI2 and the H743ZI. The mods for the ZI2 have been incorporated into the mainline code very recently.
Have you tried using two USB connections (one to the stlink port and one to the user port)? If you try to just use the user port by itself the board won't be powered up.
