Hi all,
I am trying to connect to a website (also see: http://forum.micropython.org/viewtopic.php?f=11&t=1089).
All the samples I see, first resolve the hostname to an ip-address using: socket.getaddrinfo and then call socket.connect, eg:
>>> s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
>>> sockaddr = socket.getaddrinfo('www.google.com', 80)[-1][4]
>>> print(sockaddr)
('74.125.136.104', 80)
>>> s.connect(sockaddr)
However, when I try to connect passing a tuple containing hostname and port, an error occurs:
>>> s.connect(('www.google.com', 80))
ValueError: invalid arguments
Should it be possible to call socket.connect with the hostname? If so, which mistake am I overlooking?
TIA
/Ronald
socket.connect using hostname
- danicampora
Re: socket.connect using hostname
Hi Ronald,
No, that's not possible, you need to pass the IP address.
Cheers,
Daniel
Cheers,
Daniel
