GPIO as CS for SPI
danielm
GPIO as CS for SPI
Post by danielm » Thu Nov 12, 2015 6:12 pm
Do you see any issue with using GPIOs as chip-selects for SPI devices if number of regular CS pins is not enough for my application?
Re: GPIO as CS for SPI
Post by dhylands » Thu Nov 12, 2015 6:47 pm
I think it should be fine. I also think that would be a useful feature to add to the SPI driver (ability to specify a GPIO pin as a CS).
You may need to not use the builtin CS at all (or configure it as a GPIO) since the current SPI driver probably asserts it all the time.
In the meantime, you could just do it manually.
nsoatw
Post by nsoatw » Fri Nov 13, 2015 2:20 pm
I've used GPIO for SPI-CS with good results, nothing unforseen happened.
danielm
Post by danielm » Fri Nov 13, 2015 8:59 pm
Thank you gentlemen, that's what I was hoping for :)
