PIO measuring time between pin change
podex
Post by podex » Fri Nov 19, 2021 6:41 pm
I would like to measure the time of a pulse in low level. So I used the PWM example in order to generate a pulse on the LED. And I wrote a PIO script that first waits for the pin being low and then decrements scratch register x untkl the pin goes high. At least this was the intention of this script. But it does not work, I hope that somebody can give me a hint what I did wrong or misunderstood.
Many thanks for any help!
KR,
Ch.
# Example using PWM to fade an LED.
import rp2
# measure time between falling edges
@rp2.asm_pio(set_init=rp2.PIO.IN_HIGH)
def perMeas():
    label('mainloop')
    set(x,0)
    wait(0, pin, 0)
    label('lo_loop')
    jmp(x_dec,'next')
    label('next')
    jmp(pin,'hi')
    jmp('lo_loop')
    label('hi')
    mov(isr,x)
    push()
    jmp('mainloop')
# Construct PWM object, with LED on Pin(25).
pwm = PWM(Pin(25))
# Set the PWM frequency.
pwm.freq(10)
# Fade the LED in and out a few times.
duty = 10
direction = 1
# for _ in range(8 * 256):
sm4 = rp2.StateMachine(1, perMeas, freq=200000, in_base=Pin(25)) # pin16 used
sm4.active(1)
    duty += direction
    if duty > 255:
        duty = 255
        direction = -1
    elif duty < 0:
        duty = 0
        direction = 1
    pwm.duty_u16(duty * duty)
    time.sleep(1.0)
    while sm4.rx_fifo():
        print(2**32-sm4.get(),end=' ')
        print('empty',end=' ')
    print()
Re: PIO measuring time between pin change
Post by Roberthh » Fri Nov 19, 2021 9:26 pm
I made scripts to create and time pulses using pio. See the scripts pulses at https://github.com/robert-hh/RP2040-Examples
Post by pythoncoder » Sat Nov 20, 2021 10:10 am
This script returns the period between pulses and also the pulse duration (mark) and duty ratio (mark/period):
from rp2 import PIO, StateMachine, asm_pio
@rp2.asm_pio(set_init=rp2.PIO.IN_LOW, autopush=True, push_thresh=32)
def period():
    wrap_target()
    set(x, 0)
    wait(0, pin, 0)  # Wait for pin to go low
    wait(1, pin, 0)  # Low to high transition
    label('low_high')
    jmp(x_dec, 'next') [1]  # unconditional
    label('next')
    jmp(pin, 'low_high')  # while pin is high
    label('low')  # pin is low
    jmp(x_dec, 'nxt')
    label('nxt')
    jmp(pin, 'done')  # pin has gone high: all done
    jmp('low')
    label('done')
    in_(x, 32)  # Auto push: SM stalls if FIFO full
    wrap()
def mark():
    wrap_target()
    set(x, 0)
    label('low_high')
    label('next')
    wrap()
pin16 = Pin(16, Pin.IN, Pin.PULL_UP)
sm0 = rp2.StateMachine(0, period, in_base=pin16, jmp_pin=pin16)
sm0.active(1)
sm1 = rp2.StateMachine(1, mark, in_base=pin16, jmp_pin=pin16)
sm1.active(1)
pwm = PWM(Pin(17))
pwm.freq(1000)
pwm.duty_u16(0xffff // 3)
# Clock is 125MHz. 3 cycles per iteration, so unit is 24.0ns
def scale(v):
    return (1 + (v ^ 0xffffffff)) * 24e-6  # Scale to ms
    period = scale(sm0.get())
    mark = scale(sm1.get())
    print(period, mark, mark/period)
    time.sleep(0.2)
podex
Post by podex » Mon Nov 22, 2021 7:15 pm
Many thanks, that's exactly what I am searching for! :)
My first thought is not true because when I change the pin to 25, the PIO works. I will check and double-check my code to see why it's not working as expected.
KR,
Christof
podex
Post by podex » Fri Jan 07, 2022 12:44 pm
After a while I come back to the time measurement. It took a little bit because of the festival season and I had to get the answer of the sensor correct, I have level-shifters with pull-up resistors and have to switch from drive to open-drain. But now it works, now I can focus on the measurement between falling edges.
I tried to modify my script with your example in mind. There I got a strange effect, I did not expect:
import time,utime,rp2
@rp2.asm_pio(set_init=rp2.PIO.IN_HIGH, autopush=True, push_thresh=16) # push() is done automatically win in_()!
def period():
    set(x, 1023)
    in_(x, 16)  # Auto push : SM stalls if FIFO full
    wrap_target()
    nop()
    wrap()
sm_meas = rp2.StateMachine(0, period, freq=100000, in_base=pin16, jmp_pin=pin16)
sm_meas.active(1)
    print("\nrestart ... ",end="")
    sm_meas.restart()
    print("got ",end="")
    while sm_meas.rx_fifo()>0:
        period_ticks=sm_meas.get()
        print(period_ticks,end=" ")
    utime.sleep(1)
With this code I would expect that I get the value 1023 printed, but it's not the case:
MicroPython v1.17 on 2021-09-02; Raspberry Pi Pico with RP2040
>>> %Run -c $EDITOR_CONTENT
restart ... got 0 0
restart ... got 0
restart ... got 0
What's my fault, it also does not work with bit-range 32...
Thanks for any hints!
Christof
podex
Post by podex » Fri Jan 07, 2022 2:13 pm
Maybe I should explain what I would like to do. I have a sensor with SPC interface (for an explaination see https://www.nxp.com/docs/en/application-note/AN4219.pdf) where the time between falling edges of the signal line defines the data transferred.
This is a screenshot of the Master trigger pulse with 33us low time (measurement of channel 1) and the synchronization pulse starting 272us after the start of the trigger pulse ending at 440us. So the unit time of this sensor is 3us.
In order to decode the sensor output, I need the times of the falling edges. This with the unit time gives the data nibbles.
Of course I could do it with one of the Cortex-M0+ cores, but I think this is also possible with PIO "in the background".
My concept would be the following:
The register X is set to a predefined value with the trigger pulse and then decremented. At each falling edge the register value is then pulled into the RX-FIFO. At the end from the deltas of the time of the falling edges the data nibbles can be computed with the help of the length of the synchronization pulse.
KR,
Christof
podex
Post by podex » Fri Jan 07, 2022 7:00 pm
Well, maybe I should have read the docu a little bit more carefully. set() works with data up to 31, because the number of bits in the command is limited.
@rp2.asm_pio(set_init=rp2.PIO.IN_HIGH, autopush=True, push_thresh=32) # push() is done automatically win in_()!
def period():
    set(x, 31)
    in_(x, 32)  # Auto push : SM stalls if FIFO full
    wrap_target()
    nop() [1]
    wrap()
This works as expected.
hippy
Post by hippy » Sat Jan 08, 2022 6:26 pm
The "@asm_pio" assembler is unfortunately almost completely lacking when it comes to error reporting and identifying user mistakes, is likely silently creating an instruction which is entirely different to what you wanted.
The other common mistakes which don't get reported are using 'set' with a register source, 'mov' with a numeric constant, and using registers which are not valid for a particular instruction.
If I ever get my version of the assembler which includes error reporting and allows pure text source to be specified completed and tested I will publish that.
