Second - How to do variables in assembly? With short routines I use the r0-r7 with some not changing and others as scratchpads. With longer code I used the stack but it tricky to keep my pop aligned with my pushes. At one point I tried using one r-register for all the booleans and then bit masked whichever one I needed every time. Then I settled on loading and saving from an array that I fed the routine where even each boolean uses a 16 bit word. Here is the viper code followed by my conversion:
@micropython.viper
def fill_triangle(obj_source, width_source:int,color_offset:int, y_start:int):
source=ptr16(obj_source)
c=ptr16(color_l2)
sine=ptr16(isin)
y=y_start-2
start_inside = 0
#y_tot = y - width_source//2
#color_offset-=10
while y:
x=width_source
inside=0
erase = 0
old_color=0
color = 0
while x:
i=y*width_source+x
if erase:
source[i]=c[(y+((color_offset*x)>>8))>>2] # erase color with background
x-=1
continue
old_color=color
color=source[i]
if old_color and not color: # transistion off of line
if not inside:
start_inside = x
source[i]=c[(y+((color_offset*x)>>8))>>2] # fill outside
inside^=1
elif inside:
source[i]=c[((start_inside-x)>>2)+32]#//6+32] # fill inside
if x==1:
inside = 0
x=start_inside # go back to last edge
erase =1 # erase to end of row
source[i]= c[(y+((color_offset*x)>>8))>>2]
x-=1
y-=1
and assembly:
SCREEN_CHUNK_H =const(240)
CTL_HEIGHT =const(0)
CTL_COLOR_OFFSET=const(2)
CTL_OLD_COLOR =const(4)
CTL_NEW_COLOR =const(6)
CTL_START_INSIDE=const(8)
CTL_INSIDE =const(10)
CTL_ERASE =const(12)
# control CTL_HEIGHT,CTL_COLOR_OFFSET,CTL_OLD_COLOR, CTL_NEW_COLOR, CTL_START_INSIDE, CTL_INSIDE, CTL_ERASE
control=array.array('h',(SCREEN_CHUNK_H,0,0,0,0))
@micropython.asm_thumb
def color_asm(r0,r1,r2): # r0=screen address,r1= color_l2 address, r2 = control
ldrh(r3, [r2, CTL_HEIGHT]) # r3 = working height from control
label(HLOOP) # height loop
mov(r4,0) #
strh(r4, [r2, CTL_INSIDE]) # inside=0
strh(r4, [r2, CTL_OLD_COLOR]) # old_color=0
strh(r4, [r2, CTL_NEW_COLOR]) # new_color=0
strh(r4, [r2, CTL_ERASE]) # erase=0
ldrh(r6, [r2, CTL_HEIGHT]) # r6 = working width from control (same as height)
label(WLOOP) # width loop
ldrh(r5, [r2, CTL_ERASE]) # recolor background
cmp(r5,0)
beq(NOT_ERASE)
bl(BACKCOLOR)
b(NEXT)
label(NOT_ERASE)
ldrh(r5, [r2, CTL_NEW_COLOR]) # r5 = new_color
strh(r5, [r2, CTL_OLD_COLOR]) # store in old_color
bl(SCREEN_ADDR) # r4= screen addr
ldrh(r5, [r4, 0]) # get color
strh(r5, [r2, CTL_NEW_COLOR]) # store in new_color
cmp(r5,0)
beq(CHECK_INSIDE) # skip if =0
ldrh(r5, [r2, CTL_OLD_COLOR]) # r5 = new_color
cmp(r5,0)
bgt(CHECK_INSIDE) # skip if >0
ldrh(r4, [r2, CTL_INSIDE]) # load inside
cmp(r4,1)
beq(INVERT_INSIDE)
strh(r6, [r2, CTL_START_INSIDE]) # start_inside = x
bl(BACKCOLOR)
label(INVERT_INSIDE) # inside^=1
mov(r5,1)
eor(r4,r5)
b(NEXT)
label(CHECK_INSIDE)
ldrh(r4, [r2, CTL_INSIDE]) # inside==1?
cmp(r4,0)
beq(OUTSIDE)
label(INSIDE_COLOR)
cmp(r6,1)
bne(SKIP_ERASE)
mov(r4,0)
strh(r4, [r2, CTL_INSIDE]) # inside = 0
ldrh(r6, [r2, CTL_START_INSIDE]) # x=start_inside
mov(r4,1)
strh(r6, [r2, CTL_ERASE]) # erase = 1
label(SKIP_ERASE)
ldrh(r5, [r2, CTL_START_INSIDE]) # start_inside
sub(r5,r5,r6) # start_inside-x
asr(r5,r5,1) # (start_inside-x)>>1
mov(r4,32)#32
add(r5,r5,r4)
mov(r4, 0x1) #
bic(r5,r4) # align to even bit
add(r5,r5,r1) # color_l2[r5]
ldrh(r5, [r5, 0])
strh(r5, [r4, 0]) # screen[r0]=r4
b(NEXT)
label(OUTSIDE)
bl(BACKCOLOR)
label(NEXT)
sub(r6,1) # dec working width
bgt(WLOOP)
sub(r3,1) # dec working height
bgt(HLOOP)
b(EXIT)
label(BACKCOLOR) # uses r4,r5,r6 calcs and writes pixel
ldrh(r5, [r2, CTL_COLOR_OFFSET]) # r5 = color_offset from control
mul(r5,r6) # color_offset*x
asr(r5,r5,8) # (color_offset*x)>>8)
add(r5,r5,r3) # (y+((color_offset*x)>>8)
asr(r5,r5,1) # (y+((color_offset*x)>>8))>>2
mov(r4, 0x1) #
add(r5,r5,r1) # color_l2 + (y+((color_offset*x)>>8))>>2
ldrh(r5, [r5, 0]) # r5 = color[r5]
label(SCREEN) # writes r5 to screen address
ldrh(r4, [r2, CTL_HEIGHT]) # height
mul(r4,r3) # y*height
add(r4,r4,r6) # (y*height)+x
add(r4,r4,r4) # double for 2 bytes
add(r4,r4,r0) # add to screen address
bx(lr)
label(SCREEN_ADDR) # returns screen address in r4
bx(lr)
label(EXIT)
Sam
