How To Compile for gcc newbie
blipton
Post by blipton » Tue Nov 24, 2015 12:53 am
I'd like to compile upython but not very famliar with gcc or how to setup the compiling environment. I have a Nios2, so I tried unzipping the port https://github.com/bitmachinejc/micropy ... /nios2.zip and executing './buildlib' from within the nios2 sub-folder. Unfortunately, it doesn't see the py folder/files which are there. Any suggestions how to compile either the nios2 upython library or the port comiling process in general?
Re: How To Compile for gcc newbie
Post by dhylands » Tue Nov 24, 2015 1:29 am
The first error message is:
/usr/bin/sh: python: command not found
which is needed to generate some of the source files.
So you'll need to install python.
