I figured out a way of loading up to 16 arguments in one line.
Here is four at one time but it can be repeated four times.
There is 1.6x speed improvement over repeating this four times: my_array[0] = my_value.
The store_asm() function takes four parameters and returns the memory address that they are stored at.
Then that address is fed into my main assembly routine. It sounds the same as feeding the routine an array right?
But each parameter can be changed on a single line. So this could be possible:
my_assembly(store_asm1(1,2,3,4),store_asm2(5,6,7,9),store_asm3(9,10,11,12),store_asm4(13,14,15,16))
Sam
from time import sleep_ms, sleep_us, ticks_diff, ticks_us, sleep
import array
@micropython.asm_thumb
def store_asm(r0,r1,r2,r3):
mov(r4,pc)
b(SKIP)
data(2,1,2,3,4)
align(2)
label(SKIP)
strh(r0,[r4,0])
strh(r1,[r4,2])
strh(r2,[r4,4])
strh(r3,[r4,6])
mov(r0,r4)
def retrieve_asm(r0):
ldrh(r3,[r0,6])
ldrh(r2,[r0,4])
ldrh(r1,[r0,2])
ldrh(r0,[r0,0])
def asm_test():
gticks=ticks_us()
for i in range(1000):
x=retrieve_asm(store_asm(5,6,7,8))
print(ticks_diff(ticks_us(), gticks),x)
def array_test():
gticks=ticks_us()
a[0]=5
a[1]=6
a[2]=7
a[3]=8
print(ticks_diff(ticks_us(), gticks))
a=array.array('h',(1,2,3,5))
array_test()
asm_test()
