Executing MicroPython program in non-blocking fashion
If I call "mp_call_function_0(...)" my program is blocked until that function returns (i.e. when MP program finishes). Is it possible to execute MP program in non-blocking fashion? Something like "mp_call_function_0_start(...)" and it returns immediately and later I call "mp_call_function_0_continue(...)" multiple times until it says that MP code execution is done.
Re: Executing MicroPython program in non-blocking fashion
Not sure if this is what you're after
still new to this myself
import time, _thread
def some_fn(caller, delay):
print('some_fn called by', caller)
time.sleep(delay)
print('some_fn is finished')
_thread.start_new_thread(some_fn, ('main program', 2))
print('main program called some_fn & continues')
time.sleep(3)
print('main program still running')
>>> %Run -c $EDITOR_CONTENT
some_fn called by main program
some_fn is finished
It is better to use asyncio, particularly on MicroPython. Here is the same code posted by KJM using asyncio instead:
import uasyncio as asyncio
async def some_fn(caller, delay):
await asyncio.sleep(delay)
async def main():
asyncio.create_task(some_fn('main program', 2))
await asyncio.sleep(3)
asyncio.run(main())
This is more of a question how to run embedded MicroPython interpreter inside some firmware and not how to write MicroPython code. I don't want my firmware to be blocked while python interpreter is running. I could use for example FreeRTOS and run MP interpreter in another thread, but if I have single threaded firmware I'm wondering is it possible at the same time to run both MicroPython interpreter and some other firmware code independent from MicroPython interpreter.
