Im learning about micropython on the rpi pico. In the Pi Pico Python SDK doc it shows a nice example of setting interrupts.
p2 = Pin(2, Pin.IN, Pin.PULL_UP)
p2.irq(lambda pin: print("IRQ with flags:", pin.irq().flags()), Pin.IRQ_FALLING)
And it works, when I press a button attached to a pin (I used pin 22) it reports :
IRQ with flags: 4
Ok, but what does flags 4 mean. I've looked at the micropython docs, and googled and I cant find anything about .irq().flags() at all. I'm probably missing the obvious but can anyone explain what flags 4 means and perhaps point me in the direction of some documents on this.
.irq().flags() - what is this?
Re: .irq().flags() - what is this?
A little progress - I found this:
irq.flags() get the triggers that caused the current irq. Only returns useful values when called inside the irq handler. The flags are cleared automatically when leaving the handler, therefore, this method always returns 0 when called outside.
in a document:
https://github.com/micropython/micropyt ... e-API#irqs (nothing found the the main micropython docs though)
So the irq.flags() seems to be related to the trigger. So I then tried RISING instead of FALLING
p2.irq(lambda pin: print("IRQ with flags:", pin.irq().flags()), Pin.IRQ_RISING)
and now the output is:
IRQ with flags: 8 (whereas FALLING was 4)
But still I have not found any documentation on these flag numbers
They must be useful for something
in a document:
See the RP2040 datasheet (mine is from 2021-11-04, version 150df05-clean).
Section 2.19 GPIO, and section 2.19.6 List of Registers, around page 272.
Look at registers INTR0 through INTR3.
They hold the individual flags for GPIO interrupts: each pin hi, lo, rising, falling.
It looks like they don't return the whole register, just the 4 bits for the pin that generated the interrupt.
A snippet:
GPIOx_EDGE_HIGH will give you 8, GPIOx_EDGE_LOW is 4, GPIOx_LEVEL_HIGH is 2, GPIOx_LEVEL_LOW is 1.
(I hope this made some sense.)
A snippet:
bit name type
5 GPIO1_LEVEL_HIGH
4 GPIO1_LEVEL_LOW
3 GPIO0_EDGE_HIGH wc
2 GPIO0_EDGE_LOW wc
1 GPIO0_LEVEL_HIGH ro
0 GPIO0_LEVEL_LOW ro
