Values wont update
soggycashew
Values wont update
Post by soggycashew » Sat Mar 19, 2022 3:18 pm
Hello, I have a 4 plant moisture and humidity meter on a Pico and everything runs fine when the btn_show_display is pressed BUT my values never update on the oled (Unless I stop the program and rerun). What it does when I press the button it displays temp and humidity then shows each plants capacitive soil sensors moisture percent based off the Wet/Dry Baseline Readings in the code and loops twice and shuts off oled until I press the button again and it loops again displaying the values.
What in the code do I need to change to update the values on the fly OR when the button is pressed? Please give me an example I'm new to this... Thanks!
Attached is the .py in a .zip
Moisture_And_OLED.zip
(1.56 KiB) Downloaded 81 times
import machine, time, uasyncio
from primitives.pushbutton import Pushbutton
from machine import I2C
from ads1x15 import ADS1115
from sh1106 import SH1106_I2C
from dht22 import DHT22
# Define/Initialize GPIO Pins
i2c2 = I2C(0, sda=machine.Pin(0), scl=machine.Pin(1), freq=400000)
dht22 = DHT22(machine.Pin(2,machine.Pin.IN,machine.Pin.PULL_UP))
btn_show_display = machine.Pin(3, machine.Pin.IN, machine.Pin.PULL_DOWN)
led = machine.Pin(25, machine.Pin.OUT)
#  Define Functions
# Calculate the percentage between the wet/dry values
def percentage_value(value, in_min, out_max, out_min):
        percentage_value = (value - in_min) / (out_max - out_min) * 100
        return (str(round(percentage_value))) + "%"
# Scroll in OLED screen vertically
def scroll_in_screen_v(screen):
  for i in range (0, (oled_height+1), 1):
    for line in screen:
      oled.text(line[2], line[0], -oled_height+i+line[1])
    oled.show()
    if i!= oled_height:
      oled.fill(0)
# Scroll out OLED screen vertically
def scroll_out_screen_v(speed):
  for i in range ((oled_height+1)/speed):
    for j in range (oled_width):
      oled.pixel(j, i, 0)
    oled.scroll(0,speed)
    oled.show()
# Define Variables
wet = 11344  # Wet Baseline Reading
dry = 22283  # Dry Baseline Reading
# -----------------------------------ADC Converter
adc0 = ADS1115(i2c2, 0x48, 1)  # Pins, 1st ADC Address, Gain = 1
# -----------------------------------OLED Display
oled_width = 128 # Width of OLED screen
oled_height = 64 # Height of OLED screen
oled = SH1106_I2C(oled_width, oled_height, i2c2)
# -----------------------------------Temperature & Humidity Sensor
T, H = dht22.read() # Gets Temp & Hum from dht22.py library
temp_f = T * (9/5) + 32.0 # Converts the (T) temperature to Fahrenheit degrees
# Analog-to-Digital ADC PGA Converter ADS1115--------------
adc0_result_A0 = percentage_value(adc0.read(0, 0), dry, wet, dry)
adc0_result_A1 = percentage_value(adc0.read(0, 1), dry, wet, dry)
adc0_result_A2 = percentage_value(adc0.read(0, 2), dry, wet, dry)
adc0_result_A3 = percentage_value(adc0.read(0, 3), dry, wet, dry)
    # %m.kf Converts a value of type float (or double) to m decimal positions with k digits after the period.
OLED_screen1 = [[0, 18 , "Temp: %3.0fF" %temp_f], [0, 34, "Humidity: %3.0f%%" %H]]
OLED_screen2 = [[0, 2 , "Pot 1: " + str(adc0_result_A0)],
                [0, 18, "Pot 2: " + str(adc0_result_A1)],
                [0, 34, "Pot 3: " + str(adc0_result_A2)],
                [0, 50, "Pot 4: " + str(adc0_result_A3)]]
# -----------------------------------uasyncio Coroutine
# Coroutine: blink on a timer
async def blink(delay):
        led.toggle()
        await uasyncio.sleep(delay)
async def wake_oled():  # Runs when button pressed
    for i in range(2):
    # Scroll in, stop, scroll out (vertical)
        scroll_in_screen_v(OLED_screen1)
        await uasyncio.sleep(5) # Sleep for 5 seconds (must use async sleep)
        scroll_out_screen_v(2)
        scroll_in_screen_v(OLED_screen2)
# Coroutine: entry point for asyncio program
async def main():
    pb = Pushbutton(btn_show_display)  # Create pushbutton instance
    pb.press_func(wake_oled)
    # Start coroutine as a task and immediately return
    uasyncio.create_task(blink(0.2))
        await uasyncio.sleep(1)  # You can run other code here
# Start event loop and run entry point coroutine
uasyncio.run(main())
Re: Values wont update
Post by pythoncoder » Sun Mar 20, 2022 10:35 am
I'm not sure I fully understand this. I take it that the program works as designed, updating the display each time you press the button, and you want it to update continuously. If this is what you want, the button becomes redundant - hence my confusion.
If this is what you want your main routine would look something like this:
async def run():
        await wake_oled()
async def main():
    uasyncio.create_task(run())
    # No need to launch blink and wait forever: this does the same
    await blink(0.2)
soggycashew
Post by soggycashew » Sun Mar 20, 2022 2:37 pm
Peter, the button is there so it shows the values twice and shuts off screen otherwise it would just run and run and run when not needed, It works as in that's correct but the values don't update for whatever reason and that's what I need.
What its doing is when I press the button it loops through the temp, humidity and the 4 soil sensors values and it does this twice as its supposed to BUT the values never change ever UNLESS I stop the program and restart it or unplug and plug back in and it updates the values if they had changed but again it wont update unless I stop the program and restart it or unplug it as I did before.
I hope I explained this better.... Thanks!
Peter, the only way I can get data to update without having to cut power or stop/start thonny is getting rid of the uasyncio all together and adding the while True: and moving code to below that then it works EXCEPT now I don't have it loop twice and the button is useless and I wanted it to loop twice and turn off oled.
import machine, utime
#  Define Functions
    for line in screen:
    oled.show()
    if i!= oled_height:
      oled.fill(0)
      oled.pixel(j, i, 0)
    oled.show()
# Define Variables
dry = 22486  # Dry Baseline Reading
    OLED_screen2 = [[0, 2 , "Pot 1: " + str(adc0_result_A0) + "%"],
                    [0, 18, "Pot 2: " + str(adc0_result_A1) + "%"],
                    [0, 34, "Pot 3: " + str(adc0_result_A2) + "%"],
                    [0, 50, "Pot 4: " + str(adc0_result_A3) + "%"]]
    utime.sleep(5)
    utime.sleep(5)
Post by pythoncoder » Mon Mar 21, 2022 8:57 am
OK, now I've got it. The reason is simple. In your original uasyncio code you read the values once only, for example
If you want these values to update, this must be done in a function or a coroutine. For example:
async def main():
    global T, H, temp_f, adc0_result_A0, adc0_result_A1, adc0_result_A2, adc0_result_A3
        await asyncio.sleep(5)
This should fix the problem, but it's ugly code with lots of needless globals. It would be much nicer to implement the same logic with a class, using bound variables instead of the globals.
Rather than continuously reading as above, an alternative would be to do the update as a synchronous function called immediately prior to display.
