MQ135 sensor Attribute Error
soggycashew
Post by soggycashew » Sat Apr 02, 2022 2:51 am
I'm trying to connect a mq135 gas/c02 sensor to my project and found the drivers link in Awsome MicroPython to GitHub HERE and I just cant get this thing to work. I'm using the DHT22 temp and hum sensor (I know it works) instead of the DHT11 so I had to change a few things for that. Anyways I'm getting the error:
File "<stdin>", line 12, in <module>
File "mq135.py", line 78, in get_rzero
AttributeError: 'ADC' object has no attribute 'get_resistance'
and I have no idea why? line 12 in the example is rzero = MQ135.get_rzero(adc3) and below I posted the example and driver. Sugestions?
import machine, time
from dht22 import DHT22
from mq135 import MQ135
adc3 = machine.ADC(machine.Pin(29))
dht22 = DHT22(machine.Pin(2,machine.Pin.IN,machine.Pin.PULL_UP))
    T, H = dht22.read() # Gets Temp & Hum from dht22.py library
    corrected_rzero = MQ135.get_corrected_rzero(adc3,T, H)
    resistance = MQ135.get_resistance(adc3)
    ppm = MQ135.get_ppm(adc3)
    corrected_ppm = MQ135.get_corrected_ppm(adc3,T, H)
    print("DHT22 Temperature: " + str(T) +"\t Humidity: "+ str(H))
    print("MQ135 RZero: " + str(rzero) +"\t Corrected RZero: "+ str(corrected_rzero)+
          "\t Resistance: "+ str(resistance) +"\t PPM: "+str(ppm)+
          "\t Corrected PPM: "+str(corrected_ppm)+"ppm")
    time.sleep(1)
DRIVER:
"""Micropython library for dealing with MQ135 gas sensor
Based on Arduino Library developed by G.Krocker (Mad Frog Labs)
and the corrections from balk77 and ViliusKraujutis
More info:
    https://hackaday.io/project/3475-sniffing-trinket/log/12363-mq135-arduino-library
    https://github.com/ViliusKraujutis/MQ135
    https://github.com/balk77/MQ135
import math
class MQ135(object):
    """ Class for dealing with MQ13 Gas Sensors """
    # The load resistance on the board
    RLOAD = 10.0
    # Calibration resistance at atmospheric CO2 level
    RZERO = 76.63
    # Parameters for calculating ppm of CO2 from sensor resistance
    PARA = 116.6020682
    PARB = 2.769034857
    # Parameters to model temperature and humidity dependence
    CORA = 0.00035
    CORB = 0.02718
    CORC = 1.39538
    CORD = 0.0018
    CORE = -0.003333333
    CORF = -0.001923077
    CORG = 1.130128205
    # Atmospheric CO2 level for calibration purposes
    ATMOCO2 = 397.13
    def __init__(self, pin):
        self.pin = pin
    def get_correction_factor(self, temperature, humidity):
        """Calculates the correction factor for ambient air temperature and relative humidity
        Based on the linearization of the temperature dependency curve
        under and above 20 degrees Celsius, asuming a linear dependency on humidity,
        provided by Balk77 https://github.com/GeorgK/MQ135/pull/6/files
        if temperature < 20:
            return self.CORA * temperature * temperature - self.CORB * temperature + self.CORC - (humidity - 33.) * self.CORD
        return self.CORE * temperature + self.CORF * humidity + self.CORG
    def get_resistance(self):
        """Returns the resistance of the sensor in kOhms // -1 if not value got in pin"""
        adc = ADC(self.pin)
        value = adc.read_u16()
        if value == 0:
            return -1
        return (1023./value - 1.) * self.RLOAD
    def get_corrected_resistance(self, temperature, humidity):
        """Gets the resistance of the sensor corrected for temperature/humidity"""
        return self.get_resistance()/ self.get_correction_factor(temperature, humidity)
    def get_ppm(self):
        """Returns the ppm of CO2 sensed (assuming only CO2 in the air)"""
        return self.PARA * math.pow((self.get_resistance()/ self.RZERO), -self.PARB)
    def get_corrected_ppm(self, temperature, humidity):
        return self.PARA * math.pow((self.get_corrected_resistance(temperature, humidity)/ self.RZERO), -self.PARB)
    def get_rzero(self):
        """Returns the resistance RZero of the sensor (in kOhms) for calibratioin purposes"""
        return self.get_resistance() * math.pow((self.ATMOCO2/self.PARA), (1./self.PARB))
    def get_corrected_rzero(self, temperature, humidity):
        """Returns the resistance RZero of the sensor (in kOhms) for calibration purposes
        return self.get_corrected_resistance(temperature, humidity) * math.pow((self.ATMOCO2/self.PARA), (1./self.PARB))
tepalia02
Re: MQ135 sensor Attribute Error
Post by tepalia02 » Sat Apr 02, 2022 1:12 pm
Hi, is this library properly installed in your computer? https://github.com/rubfi/MQ135
soggycashew
Post by soggycashew » Sat Apr 02, 2022 5:24 pm
Its not on my computer its on Raspbery Pi Pico? and yes its on there correctly. If I use the below code to see if the mq135 is reading values it does.
soggycashew
Post by soggycashew » Sat Apr 02, 2022 7:29 pm
I got it worked out..... I'm posting the code that works with a (DHT22 humidity and temp sensor) and the (MQ135 gas sensor).
Also you have to run/print rzero for a bit to get your RZERO and change in in the library like I did below...
RZERO = -15.01019 # OLD 76.63
mq135_dth22_example.py EXAMPLE CODE:
adc3 = MQ135(29)
        rzero = adc3.get_rzero()
        corrected_rzero = adc3.get_corrected_rzero(T, H)
        resistance = adc3.get_resistance()
        ppm = adc3.get_ppm()
        corrected_ppm = adc3.get_corrected_ppm(T, H)
        time.sleep(0.3)
mq135.py LIBRARY: with changes
More info:
import math
    RLOAD = 10.0
    RZERO = 76.63
    PARA = 116.6020682
    PARB = 2.769034857
    CORA = 0.00035
    CORB = 0.02718
    CORC = 1.39538
    CORD = 0.0018
    CORE = -0.003333333
    CORF = -0.001923077
    CORG = 1.130128205
    ATMOCO2 = 397.13
        self.pin = pin
        adc = ADC(self.pin)
#@soggy         value = adc.read()
        if value == 0:
            return -1
    def get_ppm(self):
#@soggy         return self.PARA * math.pow((self.get_resistance()/ self.RZERO), -self.PARB)
        return self.PARA * (self.get_resistance()/ self.RZERO)**-self.PARB
#@soggy         return self.PARA * math.pow((self.get_corrected_resistance(temperature, humidity)/ self.RZERO), -self.PARB)
        return self.PARA * (self.get_corrected_resistance(temperature, humidity)/ self.RZERO)**-self.PARB
def mq135lib_example():
    """MQ135 lib example"""
    # setup
    temperature = 21.0
    humidity = 25.0
    mq135 = MQ135(29) # Ghange to your analog PIN
    # loop
        rzero = mq135.get_rzero()
        corrected_rzero = mq135.get_corrected_rzero(temperature, humidity)
        resistance = mq135.get_resistance()
        ppm = mq135.get_ppm()
        corrected_ppm = mq135.get_corrected_ppm(temperature, humidity)
        time.sleep(0.3)
if __name__ == "__main__":
    mq135lib_example()
mq135_sensor_library.zip
(1.97 KiB) Downloaded 620 times
tepalia02
Post by tepalia02 » Sun Apr 03, 2022 1:22 pm
Thanks a lot. Now it will help many who are facing this problem.
ash_a
Post by ash_a » Thu Apr 07, 2022 12:28 am
I am a mac user and new to Micropython.
I am using Thonny with ESP32 and trying to figure out how to get sensor readings from an MQ135.
Could anyone help me out on how to install the "mq135" package into my MacBook!
Thanks in advance.
tepalia02
Post by tepalia02 » Thu Apr 07, 2022 2:07 pm
Thanks in advance.
I didn't have the opportunity to use Macbook. I think you'll get a better number of responses if you post your problem here: https://github.com/rubfi/MQ135/issues
