bug in constructor with default value. [SOLVED]
VladVons
Post by VladVons » Sun Apr 03, 2022 11:44 am
I found a bug in constructor with default value.
In last line aData should be [], but not a 100.
This problem also occures on Linux, Windows.
import sys
class TClass1():
    def __init__(self, aName: str, aData: list = []):
        print('aName:', aName, 'aData:', aData)
        self.Data = aData
print()
print('python ver:', sys.version_info)
print()
c1 = TClass1('ok')
c1.Data.append(100)
c2 = TClass1('ok', [1,2,3])
c3 = TClass1('err. aData cant be 100 !!!')
----- result ---:
python ver: (3, 4, 0)
aName: ok aData: []
aName: ok aData: [1, 2, 3]
aName: err. aData cant be 100 !!! aData: [100]
Знімок екрану_2022-04-03_14-33-24.png (12.38 KiB) Viewed 3490 times
rkompass
Re: bug in constructor with default value.
Post by rkompass » Sun Apr 03, 2022 2:51 pm
The 'problem' even exists on my ordinary python:
Python 3.10.2 (/usr/bin/python)
>>> %Run test_class1.py
python ver: sys.version_info(major=3, minor=10, micro=2, releaselevel='final', serial=0)
aName: ok aData: []
My interpretation: By
self.Data = aData
you introduce a reference to an object (aData), which continues to exist while the scope of aData is lost. aData was an argument and thus has only meaning within the function body ( __init()__ ).
Using
self.Data = aData.copy()
the problem is gone.
Post by pythoncoder » Sun Apr 03, 2022 5:22 pm
To put this another way, the line
        self.Data = aData
sets .Data to be a reference to the default arg aData. So when you modify .Data with
c1.Data.append(100)
you are also modifying aData. This means that when you create a new instance of TClass1 with the default list, the instance acquires the new default value. Here is a minimal demo:
>>> a = TClass1('foo')
aName: foo aData: []
>>> a.Data.append(42)
>>> b = TClass1('bar')
aName: bar aData: [42]
Default list args in Python are objects which are created once at compile time. This property can be useful in controlling allocation, but has its hazards. As @rkompass says, performing copy ensures that .Data is separate from the default list object.
VladVons
Post by VladVons » Sun Apr 03, 2022 5:43 pm
the responsibility of using 'copy()' lays on python byte compiler.
to reduce data segment the interpreter should control itself uniq values stored in hash table.
to best unerstanding see internal id() function.
though, the example with 'str' type works correct.
class TClass1():
    def __init__(self, aName: str, aData: str = ''):
        self.Data = aData
print()
c1 = TClass1('ok.')
c1.Data = 'hello'
c2 = TClass1('ok.', 'world')
c3 = TClass1('ok. aData is empty')
--- result ---
aName: ok. aData:
aName: ok. aData: world
aName: ok. aData is empty aData:
Post by dhylands » Mon Apr 04, 2022 4:54 am
Using [] or {} as default arguments is almost always a mistake. See this blog post which describes why in more detail: https://nikos7am.com/posts/mutable-default-arguments/
You’d be better to use a default value of None and then inside your function do something like:
 if arg is None:
     arg = []
This will allocate a new empty array each time the function is called rather than reusing the array that was allocated when the function was defined.
Re: bug in constructor with default value. [SOLVED]
Post by pythoncoder » Mon Apr 04, 2022 11:13 am
There is a MicroPython-specific case where a mutable list default offers a useful optimisation. That is where a hard ISR requires a fixed-length buffer. You can't allocate it in the ISR. Options are a global buffer (slow) or a buffer as a bound variable. The other way is to define the buffer as a default arg: it is allocated once at compile time.
This is safe so long as there is only one instance of the ISR. If instances of the ISR are allocated to more than one interrupt, you need to be aware that there is one buffer shared between instances. Not usually what you want...
