Pico-W Access Point static file webserver
HermannSW
Post by HermannSW » Wed Jul 06, 2022 10:20 am
I implemented a static file webserver for the Pico-W with Pico-W MicroPython firmware:
https://forums.raspberrypi.com/viewtopi ... 8#p2017461
https://github.com/Hermann-SW/pico-w
Main demo serves my planar_graph_playground (index.html, 7 .js files and new Pico-W favicon.ico):
There is a weird MicroPython bug most likely related to resource usage of webserver.
Any help in debugging/analyzing this problem is greatly appreciated.
All files needed are in the repo (including htmlsvg.js).
Biggest .js file served was htmlsvg.js of size 8096 bytes.
When requesting that file via webserver
https://github.com/Hermann-SW/pico-w/bl ... ain.py#L41
response = get_file(r)
only 6536 bytes get returned. Workaround in place in the repo is to use minimized JS file htmlsvg.min.js instead.
Surprisingly "get_file()" works if run directly in MicroPython REPL:
KeyboardInterrupt:
MicroPython v1.19.1 on 2022-07-05; Raspberry Pi Pico W with RP2040
>>> def get_file(file_name):
...     with open(file_name, 'rb') as file:
...         return file.read()
>>> print(len(get_file("htmlsvg.js")))
8096
Pico-W Access Point static file webserver:
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
Re: Pico-W Access Point static file webserver
Post by jimmo » Wed Jul 06, 2022 12:11 pm
You're going to be much better off reading small chunks of the file and streaming it back over HTTP. Try and avoid ever loading entire files at once.
You can see how microdot does it here: https://github.com/miguelgrinberg/micro ... ot.py#L468
(When you use send_file, it opens the file and sets self.body to the file object, which it then iterates using body_iter, 1024 bytes at a time.
HermannSW
Post by HermannSW » Thu Jul 07, 2022 8:06 am
Thanks for that hint !
I implemented it, and for those small files I host it works.
I did ampy put a 229283 bytes file and request that via "http://192.168.4.1/Peek_2022-07-07_02-56.gif" with wget.
Seldom I got the whole size, most times a little less.
That is because "cl.close()" seems not to wait until client has received all data.
I added "sleep_ms(100)", but that does not really help.
Commenting out "cl.close()" for letting garbage collection close the socket does not work at all.
So how can I "wait until all cl.send() data was received by client", before calling "cl.close()" ?
Current main.py:
import rp2
import socket
from time import sleep_ms
ap = network.WLAN(network.AP_IF)
ap.config(essid="pico_w_ap")
ap.active(True)
led = machine.Pin('LED', machine.Pin.OUT)
led.off()
# HTTP server with socket
addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
s = socket.socket()
s.bind(addr)
s.listen(10)
print('Listening on', addr)
# Listen for connections
        cl, addr = s.accept()
        led.on()
#        print('Client connected from', addr)
        r = str(cl.recv(1024))
#        print(r)
        r = r[r.find("/"):]
        r = r[1:r.find(" ")]
        if (r == ""):
            r = "index.html"
#        print(r)
        cl.send('HTTP/1.0 200 OK\r\nContent-type: text/html\r\n\r\n')
        send_file_buffer_size = 1024
        with open(r, 'rb') as file:
                buf = file.read(send_file_buffer_size)
                if len(buf):
                    cl.send(buf)
                if len(buf) < send_file_buffer_size:
                    break;
        sleep_ms(100)
        cl.close()
        led.off()
    except OSError as e:
        cl.close()
#        print('Connection closed')
        led.off()
Here are example wget calls demonstrating the different sizes received:
$ wget http://192.168.4.1/Peek_2022-07-07_02-56.gif 2>&1 | grep saved
2022-07-07 10:05:31 (617 KB/s) - ‘Peek_2022-07-07_02-56.gif.8’ saved [227395]
2022-07-07 10:05:33 (629 KB/s) - ‘Peek_2022-07-07_02-56.gif.9’ saved [227127]
2022-07-07 10:05:36 (625 KB/s) - ‘Peek_2022-07-07_02-56.gif.10’ saved [229283]
2022-07-07 10:05:41 (623 KB/s) - ‘Peek_2022-07-07_02-56.gif.11’ saved [229283]
2022-07-07 10:05:47 (615 KB/s) - ‘Peek_2022-07-07_02-56.gif.13’ saved [229283]
2022-07-07 10:05:49 (617 KB/s) - ‘Peek_2022-07-07_02-56.gif.14’ saved [228611]
webrepl_client.py
