nucleo F767 PWM
mpython
nucleo F767 PWM
Post by mpython » Mon Jul 18, 2022 12:30 pm
I use Nuclo F767 with micropython.
I need to set PWM in multiple timers, unfortunately, I noticed, that two different timers aren't synchronized.
Any help? And I also need to do PWM like in the picture below. and therefore I need some offset....
Thank you for any advice.
Re: nucleo F767 PWM
Post by jimmo » Tue Jul 19, 2022 1:44 am
Unfortunately you will need to configure the Timer peripheral directly via the registers.
This can be done with machine.mem32 and the register base and offsets in the stm module.
Here is an example: viewtopic.php?f=3&t=4847&p=27905#p27912
mpython
Re: nucleo F767 PWM
Post by mpython » Wed Jul 20, 2022 9:41 pm
Thank you for your help. I am still not sure how to implement timer offset. Do you have some example?
I didn't find help for stm library.
KurtHarders
Re: nucleo F767 PWM
Post by KurtHarders » Thu Jul 28, 2022 4:10 pm
what is the timing of the PWM-signals? ms or µs? Is it possible to have one timer task firing single pulse timers with the needed signals?
If timing is really tight, a RP2040 might help with its PIO statemachine.
Regards, Kurt
mpython
Re: nucleo F767 PWM
Post by mpython » Fri Jul 29, 2022 7:47 am
Hello, the timing is µs. I am not sure about firing single pulse timers.
