RTC does not start?
NielsClausen
RTC does not start?
Post by NielsClausen » Thu Mar 10, 2016 1:18 pm
The RTC on my pyboard v1.1 will not work now? It used to work however (before wiring it up to external chips). I have this MWE, but it yields nothing but the date, Jan. 1. 2000... WHY?
rtc = pyb.RTC()
print(rtc.datetime())
rtc.datetime((2016,3,10,4,9,30,10,0))
pyb.delay(2000)
I have played a bit with external powering of the board (not from USB, but through V+) - could that have interfered? I also have wires on many pins (
Screen Shot 2016-03-10 at 13.59.16.png (64.43 KiB) Viewed 8345 times
chuckbook
Re: RTC does not start?
Post by chuckbook » Thu Mar 10, 2016 8:11 pm
What is the output of rtc.info()?
After a full power cycle, including Vbat. Best to leave the board un-powered for a reasonable amount of time (1..2 minutes).
saulo
Post by saulo » Fri Jul 15, 2016 7:18 am
chuckbook wrote:What is the output of rtc.info()?
I have the same problem... i put a coil battery on vbat for five minutes and all leds turn on very weaks.. after that, i connected usb and the leds blinks normally:
>>> rtc.datetime()
(2000, 1, 1, 1, 0, 0, 0, 0)
>>> rtc.datetime()
>>> rtc.datetime()
>>> rtc.datetime()
>>> rtc.datetime()
>>> rtc.info()
262147
Post by pythoncoder » Fri Jul 15, 2016 7:30 am
@saulo With a battery providing 3V or thereabouts to vback and no power applied to V+ the LED's should not be on. I'd suggest checking your wiring.
saulo
Post by saulo » Fri Jul 15, 2016 8:32 am
pythoncoder wrote:@saulo With a battery providing 3V or thereabouts to vback and no power applied to V+ the LED's should not be on. I'd suggest checking your wiring.
Take a look pythoncoder:
i can't see nothing wrong :cry:
RTC works fine without battery, but i have to update datetime every time.. i was using the GPS to do that but it's quite annoying and not work indoor. :|
Post by pythoncoder » Fri Jul 15, 2016 9:06 am
saulo wrote:i can't see nothing wrong :cry:
I can. The RTC backup battery should be connected between vbak and gnd. The terminals you're using are for a LiPo battery. See https://micropython.org/static/store/im ... v1_1-E.jpg
saulo
Post by saulo » Fri Jul 15, 2016 3:33 pm
:oops: my bad! i correct the wiring and it's working now :mrgreen: thank you pythoncoder!
About battery pin, if i use a 1S lipo battery, i don't need power over VIN/USB right? There is not any battery management like a recharger over VIN/USB to VBAT right?
my VIN and 3V3 pins are supplied by VBAT and VIN/USB?
Post by dhylands » Fri Jul 15, 2016 4:02 pm
Wow - that's confusing.
On the older boards, VBACK used to be called VBAT.
VIN/VUSB/VBAT should all be alternate power sources for the onboard regulator. The 3V3 pin is powered from that regulator.
Post by pythoncoder » Fri Jul 15, 2016 4:27 pm
My understanding is that if you connect a LiPo battery the Pyboard will draw power from it if USB is not connected. If USB is connected, power will be drawn from there. There is no mechanism for charging the LiPo battery on the Pyboard.
saulo
Post by saulo » Fri Jul 15, 2016 9:40 pm
dhylands wrote:Wow - that's confusing.
Maybe that's why i wire wrong :roll:, i've gathered information in posts but i was not paying attention in pyboard version, thanks for the tip.
pythoncoder wrote:My understanding is that if you connect a LiPo battery the Pyboard will draw power from it if USB is not connected. If USB is connected, power will be drawn from there. There is no mechanism for charging the LiPo battery on the Pyboard.
Got it, thanks again for your help, i really appreciate it.
