I have been planning to (possibly) run Micropython under FreeDOS on a re-purposed thin client with 64MB flash, 128MB RAM and an Eden 400MHz processor for some embedded work. I am compiling with DJGPP 5.3.0 under Ubuntu 32-bit 15.10.
Problem is, I cannot get to first base!
When I clone the 2 directories found on Github and follow the instructions in "FreeDos port of micropython" I get errors. After some help from one of your contributors, I am down to this error:
Thanks for any help.
Here is the latest output of the compiler:
CC main.c
CC gccollect.c
CC unix_mphal.c
CC input.c
CC file.c
CC modmachine.c
CC modos.c
CC moduselect.c
CC alloc.c
CC coverage.c
CC modtime.c
CC modtermios.c
CC moddos.c
In file included from ../py/mpstate.h:34:0,
from ../py/runtime.h:29,
from moddos.c:9:
moddos.c:169:71: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
static MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(mod_dos_settime_obj, 4, 4, mod_dos_settime);
../py/obj.h:292:76: note: in definition of macro 'MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN'
{{&mp_type_fun_builtin}, false, n_args_min, n_args_max, .fun.var = fun_name}
moddos.c:169:71: note: (near initialization for 'mod_dos_settime_obj.fun.var')
cc1: all warnings being treated as errors
../py/mkrules.mk:47: recipe for target 'build-freedos/moddos.o' failed
make[1]: *** [build-freedos/moddos.o] Error 1
make[1]: Leaving directory '/home/berg/Desktop/micropython/micropython-master/unix'
Makefile:179: recipe for target 'freedos' failed
make: *** [freedos] Error 2
cws-combine.sh: line 3: ./exe2coff: cannot execute binary file: Exec format error
cat: micropython_freedos: No such file or directory
And here is my makefile:
include ../py/mkenv.mk
-include mpconfigport.mk
# define main target
PROG = micropython
# qstr definitions (must come before including py.mk)
QSTR_DEFS = qstrdefsport.h
# OS name, for simple autoconfig
UNAME_S := $(shell uname -s)
# include py core make definitions
include ../py/py.mk
INC += -I.
INC += -I..
INC += -I$(BUILD)
# compiler settings
CWARN = -Wall -Werror
CWARN += -Wpointer-arith -Wuninitialized
CFLAGS = $(INC) $(CWARN) -ansi -std=gnu99 -DUNIX $(CFLAGS_MOD) $(COPT) $(CFLAGS_EXTRA)
# Debugging/Optimization
ifdef DEBUG
CFLAGS += -g
COPT = -O0
else
COPT = -Os #-DNDEBUG
endif
# On OSX, 'gcc' is a symlink to clang unless a real gcc is installed.
# The unix port of micropython on OSX must be compiled with clang,
# while cross-compile ports require gcc, so we test here for OSX and
# if necessary override the value of 'CC' set in py/mkenv.mk
ifeq ($(UNAME_S),Darwin)
CC = clang
# Use clang syntax for map file
LDFLAGS_ARCH = -Wl,-map,$@.map
else
# Use gcc syntax for map file
LDFLAGS_ARCH = -Wl,-Map=$@.map,--cref
endif
LDFLAGS = $(LDFLAGS_MOD) $(LDFLAGS_ARCH) -lm $(LDFLAGS_EXTRA)
ifeq ($(MICROPY_FORCE_32BIT),1)
# Note: you may need to install i386 versions of dependency packages,
# starting with linux-libc-dev:i386
ifeq ($(MICROPY_PY_FFI),1)
ifeq ($(UNAME_S),Linux)
CFLAGS_MOD += -I/usr/include/i686-linux-gnu
endif
endif
endif
ifeq ($(MICROPY_USE_READLINE),1)
INC += -I../lib/mp-readline
CFLAGS_MOD += -DMICROPY_USE_READLINE=1
LIB_SRC_C_EXTRA += mp-readline/readline.c
endif
ifeq ($(MICROPY_USE_READLINE),2)
CFLAGS_MOD += -DMICROPY_USE_READLINE=2
LDFLAGS_MOD += -lreadline
# the following is needed for BSD
#LDFLAGS_MOD += -ltermcap
endif
ifeq ($(MICROPY_PY_TIME),1)
CFLAGS_MOD += -DMICROPY_PY_TIME=1
SRC_MOD += modtime.c
endif
ifeq ($(MICROPY_PY_TERMIOS),1)
CFLAGS_MOD += -DMICROPY_PY_TERMIOS=1
SRC_MOD += modtermios.c
endif
ifeq ($(MICROPY_PY_SOCKET),1)
CFLAGS_MOD += -DMICROPY_PY_SOCKET=1
SRC_MOD += modsocket.c
endif
ifeq ($(MICROPY_STANDALONE),1)
LIBFFI_CFLAGS_MOD := -I$(shell ls -1d ../lib/libffi/build_dir/out/lib/libffi-*/include)
LIBFFI_LDFLAGS_MOD = ../lib/libffi/build_dir/out/lib32/libffi.a
else
LIBFFI_LDFLAGS_MOD = ../lib/libffi/build_dir/out/lib/libffi.a
endif
else
LIBFFI_CFLAGS_MOD := $(shell pkg-config --cflags libffi)
LIBFFI_LDFLAGS_MOD := $(shell pkg-config --libs libffi)
endif
LIBFFI_LDFLAGS_MOD += -ldl
endif
CFLAGS_MOD += $(LIBFFI_CFLAGS_MOD) -DMICROPY_PY_FFI=1
LDFLAGS_MOD += $(LIBFFI_LDFLAGS_MOD)
SRC_MOD += modffi.c
endif
ifeq ($(MICROPY_PY_JNI),1)
# Path for 64-bit OpenJDK, should be adjusted for other JDKs
CFLAGS_MOD += -I/usr/lib/jvm/java-7-openjdk-amd64/include -DMICROPY_PY_JNI=1
SRC_MOD += modjni.c
endif
ifeq ($(MICROPY_PY_MODDOS), 1)
SRC_MOD += moddos.c
endif
# source files
SRC_C = \
main.c \
gccollect.c \
unix_mphal.c \
input.c \
file.c \
modmachine.c \
modos.c \
moduselect.c \
alloc.c \
coverage.c \
$(SRC_MOD)
# Include builtin package manager in the standard build (and coverage)
ifeq ($(PROG),micropython)
SRC_C += $(BUILD)/_frozen_upip.c
else ifeq ($(PROG),micropython_coverage)
else ifeq ($(PROG), micropython_freedos)
endif
LIB_SRC_C = $(addprefix lib/,\
$(LIB_SRC_C_EXTRA) \
utils/printf.c \
OBJ = $(PY_O)
OBJ += $(addprefix $(BUILD)/, $(SRC_C:.c=.o))
OBJ += $(addprefix $(BUILD)/, $(LIB_SRC_C:.c=.o))
include ../py/mkrules.mk
.PHONY: test
test: $(PROG) ../tests/run-tests
$(eval DIRNAME=$(notdir $(CURDIR)))
cd ../tests && MICROPY_MICROPYTHON=../$(DIRNAME)/$(PROG) ./run-tests
# install micropython in /usr/local/bin
TARGET = micropython
PREFIX = $(DESTDIR)/usr/local
BINDIR = $(PREFIX)/bin
PIPSRC = ../tools/pip-micropython
PIPTARGET = pip-micropython
install: micropython
install -D $(TARGET) $(BINDIR)/$(TARGET)
install -D $(PIPSRC) $(BINDIR)/$(PIPTARGET)
# uninstall micropython
uninstall:
-rm $(BINDIR)/$(TARGET)
-rm $(BINDIR)/$(PIPTARGET)
# build synthetically fast interpreter for benchmarking
fast:
$(MAKE) COPT="-O2 -DNDEBUG -fno-crossjumping" CFLAGS_EXTRA='-DMP_CONFIGFILE="<mpconfigport_fast.h>"' BUILD=build-fast PROG=micropython_fast
# build a minimal interpreter
minimal:
$(MAKE) COPT="-Os -DNDEBUG" CFLAGS_EXTRA='-DMP_CONFIGFILE="<mpconfigport_minimal.h>"' BUILD=build-minimal PROG=micropython_minimal MICROPY_PY_TIME=0 MICROPY_PY_TERMIOS=0 MICROPY_PY_SOCKET=0 MICROPY_PY_FFI=0 MICROPY_USE_READLINE=0
freedos:
$(MAKE) \
CC=i586-pc-msdosdjgpp-gcc \
STRIP=i586-pc-msdosdjgpp-strip \
SIZE=i586-pc-msdosdjgpp-size \
CFLAGS_EXTRA='-DMP_CONFIGFILE="<mpconfigport_freedos.h>" -DMICROPY_NLR_SETJMP -Dtgamma=gamma -DMICROPY_EMIT_X86=0 -DMICROPY_NO_ALLOCA=1 -DMICROPY_PY_USELECT=0' \
BUILD=build-freedos \
PROG=micropython_freedos \
MICROPY_PY_SOCKET=0 \
MICROPY_PY_FFI=0 \
MICROPY_PY_JNI=0 \
MICROPY_PY_MODDOS=1
# build an interpreter for coverage testing and do the testing
coverage:
$(MAKE) COPT="-O0" CFLAGS_EXTRA='-fprofile-arcs -ftest-coverage -Wdouble-promotion -Wformat -Wmissing-declarations -Wmissing-prototypes -Wold-style-definition -Wpointer-arith -Wshadow -Wsign-compare -Wuninitialized -Wunused-parameter -DMICROPY_UNIX_COVERAGE' LDFLAGS_EXTRA='-fprofile-arcs -ftest-coverage' BUILD=build-coverage PROG=micropython_coverage
coverage_test: coverage
cd ../tests && MICROPY_MICROPYTHON=../$(DIRNAME)/micropython_coverage ./run-tests
cd ../tests && MICROPY_MICROPYTHON=../$(DIRNAME)/micropython_coverage ./run-tests --emit native
gcov -o build-coverage/py ../py/*.c
gcov -o build-coverage/extmod ../extmod/*.c
$(BUILD)/_frozen_upip.c: $(BUILD)/frozen_upip/upip.py
../tools/make-frozen.py $(dir $^) > $@
# Select latest upip version available
UPIP_TARBALL := $(shell ls -1 -v ../tools/micropython-upip-*.tar.gz | tail -n1)
$(BUILD)/frozen_upip/upip.py: $(UPIP_TARBALL)
$(ECHO) "MISC Preparing upip as frozen module"
$(Q)rm -rf $(BUILD)/micropython-upip-*
$(Q)tar -C $(BUILD) -xz -f $^
$(Q)rm -rf $(dir $@)
$(Q)mkdir -p $(dir $@)
$(Q)cp $(BUILD)/micropython-upip-*/upip*.py $(dir $@)
# Value of configure's --host= option (required for cross-compilation).
# Deduce it from CROSS_COMPILE by default, but can be overriden.
ifneq ($(CROSS_COMPILE),)
CROSS_COMPILE_HOST = --host=$(patsubst %-,%,$(CROSS_COMPILE))
else
endif
deplibs: libffi axtls
# install-exec-recursive & install-data-am targets are used to avoid building
# docs and depending on makeinfo
libffi:
cd ../lib/libffi; git clean -d -x -f
cd ../lib/libffi; ./autogen.sh
mkdir -p ../lib/libffi/build_dir; cd ../lib/libffi/build_dir; \
../configure $(CROSS_COMPILE_HOST) --prefix=$$PWD/out CC="$(CC)" CXX="$(CXX)" LD="$(LD)"; \
make install-exec-recursive; make -C include install-data-am
axtls:
cd ../lib/axtls; cp config/upyconfig config/.config
cd ../lib/axtls; make oldconfig -B
cd ../lib/axtls; make clean
cd ../lib/axtls; make all CC="$(CC)" LD="$(LD)"
I have made one change to the source:
In mpconfigport_freedos.h
I changed MP_QSTR_machine
to
MP_QSTR_umachine
And one change to build_freedos.sh:
changed 5.2.0
to 5.3.0
Trying to build MicroPython for FreeDOS on Ubuntu 15.10
Re: Trying to build MicroPython for FreeDOS on Ubuntu 15.10
I created a freedos branch in my repository that builds:
https://github.com/dhylands/micropython/tree/freedos
The patch was fairly small:
https://github.com/dhylands/micropython ... 39d2e58d74
but not suitable for merging into master.
The unix build currently can't be built with FatFs disabled.
berghawkins, you should not use https://github.com/pohmelie/micropython-freedos cause micropython is fast growing and lots of changes was made for last 4 months. I will update this repo later (after async/await will be aplied/rejected). Just use unix build with micropython target, as dhylands said.
dhylands, maybe create issue for this? Or should I try to create switching for makefile for those modules?
dhylands, what do you think about this patch?
https://github.com/pohmelie/micropython ... e9a8265c8d
Also, I've found that "make clean" does not remove build-freedos directory and micropython-freedos binaries. And there is not target for "clean" in makefile.
The clean target is actually in py/mkrules.mkpohmelie wrote:Also, I've found that "make clean" does not remove build-freedos directory and micropython-freedos binaries. And there is not target for "clean" in makefile.
We probably need to add some dependencies on clean so that other build directories get removed as well.
That looks reasonable to me (on my phone)pohmelie wrote:dhylands, what do you think about this patch?
Ok, I'm ended with pull right now. https://github.com/micropython/micropython/pull/1956dhylands wrote:That looks reasonable to me (on my phone)
Hm, I see removing of $(PROG) and $(BUILD), but unix makefile have proper values for freedosdhylands wrote:The clean target is actually in py/mkrules.mk
