LCD skin Graphic-Demo
polygontwist
Post by polygontwist » Sun Jun 29, 2014 10:35 pm
i have adapted the code from "Adafruit-GFX-Library-master" for graphic lcd.
origin: https://github.com/adafruit/Adafruit-GFX-Library
lcd = pyb.LCD('X')	#128*32
lcd.light(1)
def drawFillRect(x,y,w,h,thelcd,fill):
	xa=x
	xe=x+w
	ya=y
	ye=y+h
	if xa>xe:
		t=xa
		xa=xe
		xe=t
	if ya>ye:
		t=ya
		ya=ye
		ye=t
	for yy in range(ya, ye):
		for xx in range(xa,xe):
			thelcd.pixel(xx,yy,fill)
def drawLine(x0,y0,x1,y1,thelcd,fill):
	steep= abs(y1 - y0) > abs(x1 - x0);
	if steep:
		x0, y0 = y0, x0
		x1, y1 = y1, x1
	if x0>x1:
		x0, x1 = x1, x0
		y0, y1 = y1, y0
	dx=x1-x0
	dy=abs(y1-y0)
	err=dx/2
	ystep=-1
	if y0 < y1: ystep = 1
	for xx in range(x0, x1):
		if steep:
			thelcd.pixel(y0,xx,fill)
			thelcd.pixel(xx,y0,fill)
		err-=dy
		if err<0:
			y0+=ystep
			err+=dx
def drawRect(x,y,w,h,thelcd,fill):
	drawLine(x,y,x+w,y,thelcd,fill)
	drawLine(x+w-1,y,x+w-1,y+h,thelcd,fill)
	drawLine(x+w,y+h-1,x,y+h-1,thelcd,fill)
	drawLine(x,y+h,x,y,thelcd,fill)
def drawCircle(x0,y0,r,thelcd,fill):
	f=1-r
	ddF_x = 1
	ddF_y = -2 * r
	x = 0
	y = r
	thelcd.pixel(x0  , y0+r,fill)
	thelcd.pixel(x0  , y0-r,fill)
	thelcd.pixel(x0+r, y0  ,fill)
	thelcd.pixel(x0-r, y0  ,fill)
	while x<y:
		if f>=0:
			y-=1
			ddF_y+=2
			f+=ddF_y
		x+=1
		ddF_x+=2
		f+=ddF_x
		thelcd.pixel(x0+x, y0+y, fill);
		thelcd.pixel(x0-x, y0+y, fill);
		thelcd.pixel(x0+x, y0-y, fill);
		thelcd.pixel(x0-x, y0-y, fill);
		thelcd.pixel(x0+y, y0+x, fill);
		thelcd.pixel(x0-y, y0+x, fill);
		thelcd.pixel(x0+y, y0-x, fill);
		thelcd.pixel(x0-y, y0-x, fill);
def drawfillCircle(x0,y0,r,thelcd,fill):
	drawLine(x0, y0-r, x0,y0-r+2*r+1,thelcd, fill)
	f   = 1 - r
	ddF_x = 1
	ddF_y = -2 * r
	x = 0
	y = r
	while x<y:
		if f>=0:
			y-=1
			ddF_y+=2
			f+=ddF_y
		x+=1
		ddF_x+=2
		f+=ddF_x
		drawLine(x0+x, y0-y, x0+x, y0-y+2*y+1,thelcd, fill);
		drawLine(x0+y, y0-x, x0+y, y0-x+2*x+1,thelcd, fill);
		drawLine(x0-x, y0-y, x0-x, y0-y+2*y+1,thelcd, fill);
		drawLine(x0-y, y0-x, x0-y, y0-x+2*x+1,thelcd, fill);
lcd.fill(0)
drawRect(0,0,10,16,lcd,1)
drawFillRect(15,0,10,16,lcd,1)
drawLine(0,31,30,16, lcd,1)
drawfillCircle(64,16,10,lcd,1)
drawCircle(128-6,32-6, 5,lcd,1)
lcd.show()
polygontwist
lcd_gfx library
Post by polygontwist » Thu Jul 03, 2014 9:08 pm
the gfx-graphics functions as a library:
  • drawLine
  • drawTrie
  • drawFillTrie
  • drawRect
  • drawFillRect
  • drawCircle
  • drawfillCircle
file "lcd_gfx.py":
#adaptiert von Adafruit_GFX.cpp
#for LCD and touch-sensor skin
	if steep:
		x0, y0 = y0, x0
		x1, y1 = y1, x1
	if x0>x1:
		x0, x1 = x1, x0
		y0, y1 = y1, y0
	dx=x1-x0
	dy=abs(y1-y0)
	err=dx/2
	ystep=-1
		if steep:
		err-=dy
		if err<0:
			y0+=ystep
			err+=dx
def drawTrie(x0,y0,x1,y1,x2,y2,thelcd,fill):
	drawLine(x2,y2,x1,y1,thelcd,fill)
	drawLine(x2,y2,x0,y0,thelcd,fill)
def drawFillTrie(x0,y0,x1,y1,x2,y2,thelcd,fill):
	if y0 > y1:
		y0, y1=y1, y0
		x0, x1=x1, x0
	if y1 > y2:
		y2, y1=y1,y2
		x2, x1=x1,x2
	if y0 > y1:
		y0, y1=y1,y0
		x0, x1=x1,x0
	if y0 == y2:
		a = x0
		b = x0
		if x1 < a:
			a = x1
			if x1 > b:
				b = x1
		if x2 < a:
			a = x2
			if x2 > b:
				b = x2
		drawLine(a, y0,b+1,y0,thelcd,fill)
		return
	dx01 = x1 - x0
	dy01 = y1 - y0
	dx02 = x2 - x0
	dy02 = y2 - y0
	dx12 = x2 - x1
	dy12 = y2 - y1
	sa   = 0
	sb   = 0
	if y1 == y2:
		last = y1
		last = y1-1
	y=y0
	for y in range(y0, last+1):
		a= x0 + sa / dy01
		b= x0 + sb / dy02
		sa += dx01
		sb += dx02
		if a > b:
			a,b=b,a
		drawLine(int(a), y,int(b+1),y,thelcd,fill)
	sa = dx12 * (y - y1)
	sb = dx02 * (y - y0)
	for y in range(last+1, y2+1):
		a   = x1 + sa / dy12
		b   = x0 + sb / dy02
		sa += dx12
		sb += dx02
		if a > b:
			a,b=b,a
	xa=x
	xe=x+w
	ya=y
	ye=y+h
	if xa>xe:
		xa,xe = xe,xa
	if ya>ye:
		ya,ye=ye,ya
	f=1-r
	ddF_x = 1
	ddF_y = -2 * r
	x = 0
	y = r
	while x<y:
		if f>=0:
			y-=1
			ddF_y+=2
			f+=ddF_y
		x+=1
		ddF_x+=2
		f+=ddF_x
	f   = 1 - r
	ddF_x = 1
	ddF_y = -2 * r
	x = 0
	y = r
	while x<y:
		if f>=0:
			y-=1
			ddF_y+=2
			f+=ddF_y
		x+=1
		ddF_x+=2
		f+=ddF_x
Demo for file "main.py":
import lcd_gfx
i2c = pyb.I2C(1, pyb.I2C.MASTER)
i2c.mem_write(4, 90, 0x5e)
switch = pyb.Switch()
lcd.light(1)
intensity = 0
counter = 1
myled=pyb.LED(4)
while not switch():
	intensity=intensity+counter
	if intensity>15: counter=-1
	if intensity<1: counter=1
	lcd.fill(0)
	x0=0 +int(intensity/3)
	y0=0
	x1=25
	y1=5+int(intensity/2)
	x2=5+intensity*2
	y2=25
	lcd_gfx.drawFillTrie(x0,y0, x1,y1,  x2,y2, lcd,1 )
	x0+=50
	x1+=50
	x2+=50
	lcd_gfx.drawTrie(x0,y0, x1,y1,  x2,y2, lcd,1)
	lcd.show()
	myled.intensity(intensity)
	pyb.delay(12)
Video:
http://instagram.com/p/qAM4RUTftc
have fun.
Markus Gritsch
Re: LCD skin Graphic-Demo
Post by Markus Gritsch » Fri Jul 04, 2014 11:12 am
In the video there seems to be an irregular refresh rate. Maybe you can try adding
gc.collect()
in the loop somewhere. It solved my issue with random garbage collector related delays (http://forum.micropython.org/viewtopic. ... t=108#p580)
Cheers,
Markus
polygontwist
Post by polygontwist » Fri Jul 04, 2014 6:15 pm
thank you, its works better!
nande
Post by nande » Mon Nov 03, 2014 9:29 pm
Awesome thanks!
~namida de ashita ga mienai~
