Redirecting terminal/WebRepl to OLED 1306
pythonista
Post by pythonista » Mon Jun 20, 2016 6:21 pm
Any idea how can I easily redirect terminal output to OLED screen while typing over webrepl ?
I would really like to make "stand alone" python terminal :lol:
Re: Redirecting terminal/WebRepl to OLED 1306
Post by deshipu » Mon Jun 20, 2016 8:05 pm
I would look at how WebREPL does it (https://github.com/micropython/micropyt ... dwebrepl.c). I think it involves the os.dupterm call.
HermannSW
Post by HermannSW » Mon Oct 01, 2018 6:36 pm
Seems to be doable (I could read after Google translate Chinese->English):
https://blog.boochow.com/article/oled-c ... pterm.html
Gist reply-to-oled.py can be found here:
https://gist.github.com/boochow
from machine import I2C
i2c=I2C(1)
i2c.init(freq=1000000)
oled = SSD1306_I2C(128, 64, i2c)
console = FBConsole(oled)
os.dupterm(console)
I did copy FBConsole.py from there to ESP32 module with Oled:
$ ~/webrepl/webrepl_cli.py FBConsole.py 192.168.4.1:
Password:
op:put, host:192.168.4.1, port:8266, passwd:abcd.
FBConsole.py -> /FBConsole.py
Remote WebREPL version: (1, 9, 4)
Sent 2294 of 2294 bytes
My ESP32 module boots up with "oled" already:
https://www.esp32.com/viewtopic.php?f=2 ... 240#p31240
"oled" is created as the oled in Gist in my boot.py.
Unfortunately the next line from Gist does not work:
>>> from FBConsole import FBConsole
  File "FBConsole.py", line 3, in <module>
AttributeError: 'module' object has no attribute 'IOBase'
>>> import FBConsole
TypeError: 'module' object is not callable
What am I missing? Or is the Gist just for Python and not for MicroPython?
mattyt
Post by mattyt » Mon Oct 01, 2018 11:01 pm
Hi HermanSW,
That looks like legitimate MicroPython code (the 'u' prefixing . And uio.IOBase exists, at least on my recent-ish 1.9.4 build:
MicroPython v1.9.4-564-gcb3c66e79 on 2018-09-21; ESP32 module with ESP32
>>> import uio
>>> uio.
__class__       __name__        BufferedWriter  BytesIO
FileIO          IOBase          StringIO        TextIOWrapper
open
Which version of MicroPython are you running?
Googling the issue does identify a possible hint. Do you have an 'io' directory on the filesystem that could be confusing the import?
HermannSW
Post by HermannSW » Tue Oct 02, 2018 8:08 pm
1.9.4 from May, see below.
No, I flashed MicroPython and had just single boot.py file then.
Never created directories, see below for which files are in filesystem:
$ webrepl_client.py 192.168.4.1
Password:
WebREPL connected
MicroPython v1.9.4 on 2018-05-11; ESP32 module with ESP32
>>> uos.listdir()
['boot.py', 'webrepl_cfg.py', 'ssd1306.py', 'pye.py', 'FBConsole.py']
P.S:
>>> import uio
>>> help(uio)
object <module 'uio'> is of type module
  __name__ -- uio
  open -- <function>
  FileIO -- <class 'FileIO'>
  TextIOWrapper -- <class 'TextIOWrapper'>
  StringIO -- <class 'StringIO'>
  BytesIO -- <class 'BytesIO'>
  BufferedWriter -- <class 'BufferedWriter'>
boochow
Post by boochow » Wed Oct 03, 2018 1:58 pm
IOBase had been added on 4 June.
https://github.com/micropython/micropyt ... 69700b0bee
An older version of FBClass.py is here, which I had written before IOBase was added.
https://gist.github.com/boochow/4163e00 ... 4c359527aa
hope this helps!
HermannSW
Post by HermannSW » Wed Oct 03, 2018 9:02 pm
Thank you! -- my fault.
I just installed latest 1.9.4
MicroPython v1.9.4-623-g34af10d2e on 2018-10-03; ESP32 module with ESP32
after copying off all files with webrepl_cli.py, then I did screen session into ESP32, activated AP, enabled WebREPL and copied in all files via webrepl_cli.py again.
After reboot my Oled screen did show up nicely.
Then only 3 commands later REPL did show up on Oled!!
>>> os.dupterm(console)
<_webrepl>
P.S:
Ooops, seems I don't have matching ssd1306.py ... which ssd1306.py do you use?
>>> os.listdir()
['boot.py', 'webrepl_cfg.py', 'FBConsole.py', 'pdupterm: Exception in write() method, deactivating: Traceback (most recent call last):
  File "FBConsole.py", line 62, in write
  File "FBConsole.py", line 50, in _putc
  File "FBConsole.py", line 77, in _newline
AttributeError: 'SSD1306_I2C' object has no attribute 'fill_rect'
ye.py', 'ssd1306.py']
HermannSW
Post by HermannSW » Wed Oct 03, 2018 9:23 pm
Wow!
I did google for "ssd1306.py fille_rect" and found this:
https://git.zgyarmati.de/zgyarmati/micr ... ssd1306.py
Then I did download it and copied it over to ESP32.
Adter doing soft reboot in screen session my initial Oled screen showed nicely.
Then doing the three commands from previous posting and REPL started on Oled.
This time without issues, with line scrolling, ...
Post by pythoncoder » Thu Oct 04, 2018 5:01 am
I did google for "ssd1306.py fille_rect" and found this...
Is there a problem with the official version? It definitely supports fill_rect().
HermannSW
Post by HermannSW » Thu Oct 04, 2018 12:15 pm
Thanks for asking, I looked at it but found no "fill_rect" in that file.
Anyway I tried it and copied over to ESP32 module.
My normal boot.py Oled comands worked,
as well os.dupterm with FBConsole. I will keep using the official ssd1306.py from now on.
While 16x8 character display might not be that useful to interact with MicroPython REPL, bigger displays definitely are.
I really would like to see FBConsole from Boochow
https://gist.github.com/boochow/4163e00 ... 17cfc0297c
being part of official MicroPython.
If possible his repl-to-oled.py (as sample) somehow as well:
https://gist.github.com/boochow/f3bbd6a ... 20cbd9f9e0
Working with REPL is cool, accessing history commands with arrow up/down is fine. Moving cursor left seems to erase the character on display, but "END" key makes all visible again. I found a little bug sofar, if getting a history command, doing some arrow left, and then change something, is correct for first change action, but display gets scrambled for 2nd (like delete character, then insert new). Only display is scrambled, command is still correct as can be seen by pressing Return.
