Half-decent LED-PWM and capacitive-sense GPIO coroutines
nmz787
Post by nmz787 » Sun Jul 10, 2016 10:15 pm
(edited because I figured out how to get PWM working for the LED, and results are marginally better) (and again to enable BBCode)
The idea is to set a GPIO pin LOW, then as an INPUT, and see how long (based on capacitive field of your body moving to and from) the pin registers as HIGH. I try to self-calibrate by finding the min and max readings for how long it takes (iterations/cycles of a loop) to detect the INPUT change... so train the MCU by moving toward and away from the MCU a few times. It is not a linear response, it is most apparent within an inch or so of the MCU. The LED intensity(value) method didn't work for me, so I had to try and do a fake-PWM on the LED... any improvements for linearizing the response and making the LED nicer would be appreciated!
from pyb import Timer
# timer 2 will be created with a frequency of 10 kHz
tim=pyb.Timer(2,freq=10000);
# attach the timer to the LED GPIO, turning the brightness OFF to begin
tchannel = tim.channel(1, Timer.PWM, pin=pyb.Pin.board.LED_GREEN, pulse_width_percent=0)
# setup comm channel, for debug prints
# uart = pyb.UART(2, 9600)                         # init with given baudrate
# uart.init(9600, bits=8, parity=None, stop=1)
glob_max = glob_min = glob_span = 0
max_num_check_cycles = 50000
update_func = None
def later_update_func(current):
    use the min and max to calculate a range of sensor readings, then normalize the current reading
    finally scale the normalized reading to a 0-100 percentage value, cast to Integer
    then finally update the Timer PWM percentage
    global glob_min
    global glob_max
    global glob_span
    global tchannel
    glob_max = max(current, glob_max)
    glob_min = min(current, glob_min)
    glob_span = glob_max - glob_min
    if (glob_span) > 0:
        glob_dly = (((current-glob_min)/(glob_span))*100)
        glob_dly = int(glob_dly)
    tchannel.pulse_width_percent(glob_dly)
    # uart.write('LATER UPDATE {}\n'.format(glob_dly))
def first_update_func(i):
    set up the initial values for min and max of sensor range,
    then switch the update func to "later_update_func" (I think this avoids an "if" branch code)
    global glob_min
    global glob_max
    global update_func
    glob_max = i
    glob_min = i
    update_func = later_update_func
    # uart.write('FIRST UPDATE\n')
update_func = first_update_func
def gpio_cap_sense():
    GPIO capacitive sense
    global update_func
        # Discharge the pin first by setting it low and output
        g = pyb.Pin(pyb.Pin.board.A0, pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
        g.value(True)
        pyb.delay(1)
        # Make the pin an input WITHOUT the internal pull-up on
        g = pyb.Pin(pyb.Pin.board.A0, pyb.Pin.IN, pyb.Pin.PULL_NONE)
        i=0
        # Now see how many cycles it takes to get the pin pulled up
        while i<max_num_check_cycles:
            # apparently there is some inverter,
            # such that I need to check when the pin goes apparently-low???
            if not g.value():
                update_func(i)
                break
            i+=1
        yield
# set up co-tasks
tasks = [gpio_cap_sense()]
# loop through each task forever
while 1:
    for t in tasks:
        next(t)
nmz787
Re: Half-decent fake-LED-PWM and capacitive-sense GPIO coroutines
Post by nmz787 » Sun Jul 10, 2016 10:43 pm
Since BBCode isn't enabled for my user, here is the code on github for readability:
https://gist.github.com/nmz787/afc7fea4 ... ce5da0c52d
Re: Half-decent LED-PWM and capacitive-sense GPIO coroutines
Post by pythoncoder » Mon Jul 11, 2016 7:12 am
I wonder if capacitive sensing would work better using an ADC? Link an ADC input to a DAC output. Set the DAC to half scale to charge the capacitance to 1.65V, then turn the DAC pin to a digital input to make it high impedance. Then take periodic readings from the ADC. This would allow for the situation where the capacitance change causes the voltage to fall - as far as I can see there's no guarantee which way it will move so you need to measure the absolute value of any change from the initial reading.
In my youth I experimented with capacitive sensing using a different sensing technique. I found sensitivity was improved by using a metal plate as the sensor - of course this needs to be well insulated and I mounted it behind a perspex sheet.
Nonlinearity is inevitable as the relationship between distance and capacitance is nonlinear. The capacitance between a pair of conductive plates is proportional to area/distance.
