Change hostname.
markxr
Re: Change hostname.
Post by markxr » Thu Sep 08, 2016 5:35 pm
The obvious thing to do is to add a new keyword argument to sta.config(... ) - it already has keyword arguments for other parameters.
The function is esp_config in modnetwork.c. It's just a matter of adding a new case: in the argument checking and calling that function wifi_station_set_hostname. Seems easy enough.
mogul
Post by mogul » Sun Apr 16, 2017 9:04 pm
A year later I came across the same problem, and now it is straight forward to change hostname.
wlan.config(dhcp_hostname="foo-bar-baz")
MCHobby
Post by MCHobby » Mon Sep 18, 2017 8:33 pm
I'm using ESP8266 under MicroPython.
I had use the default ESP8266 hostname from WebRepl and find this really convenient when using the network DHCP. I'm using the modem-router from the Internet Provider.
Using "ws://ESP_xxxx:8266" with WebRepl is really a dream.
However, from time to time this Hostname purely disappears from the network :-(
What the hell to find the new IP for WebRepl(ing).
I have seen in this thread https://www.tapatalk.com/topic/182447-m ... n-hostname explaining that ESP8266 reboot would not republish the hostname to the DHCP server (from the last SSID/Password stored in the ESP)
So I tried to connect a wrong network then back to the right network to resend the ESP hostname with DHCP register.
Unfortunately it doesn't work as expected.
I did identify the
now available in MicroPython sysname='esp8266' release='2.0.0(5a875ba)', version='v1.9.1-8-g7213e78d on 2017-06-12' but cannot get it to push the hostname to the DHCP/DNS server.
Is there an appropriate sequence of instruction to follows ?
Is this depending on my own computer resolve names? (using Linux Mint/Ubuntu/Debian, he resolve properly the name of the other computer on the network).
Any suggestion would be welcome. I'm puzzled.
