WeMos D1 Mini Pro 16MB
mcauser
Post by mcauser » Wed Aug 31, 2016 3:09 pm
WeMos have released a D1 Mini Pro.
  • ESP-12F replaced with onboard components, no metal cover.
  • 16MB flash (128Mbit)
  • Built in ceramic antenna + external connector
  • CP2104 USB-UART (changed from CH340G)
  • Same dimensions as D1 Mini, compatible with existing shields
  • Lighter and thinner than D1 mini
  • USB + reset buttons moved to the top of PCB
  • $1 more expensive than D1 mini
https://www.aliexpress.com/item/WEMOS-D ... .56.5Zx1NW
$5 USD
Re: WeMos D1 Mini Pro 16MB
Post by pythoncoder » Wed Aug 31, 2016 4:00 pm
Odd that the chip isn't shielded: their other products have a WeMos branded, shielded chip. Odder still it doesn't appear on the WeMos official site. I smell a rat.
quantalume
Post by quantalume » Wed Aug 31, 2016 4:20 pm
I ordered a couple, so we will see what this "rat" looks like. I like having the antenna connector as I put all my IoT devices in metal boxes.
Post by deshipu » Wed Aug 31, 2016 7:49 pm
pythoncoder wrote:Odder still it doesn't appear on the WeMos official site. I smell a rat.
This is consistent with how their other products first appear at Aliexpress, and only after a couple of days on their website. I think the website is being updated by someone who is quite busy with other things too. It was like that with the motor shield too.
Post by pythoncoder » Thu Sep 01, 2016 8:48 am
Perhaps I'm being too suspicious, then - but I gather there are a lot of dodgy clones of WeMos devices. I think abandoning shielding represents a decline in build quality and I doubt an unshielded module can achieve FCC approval.
The antenna connection is a great improvement.
Post by deshipu » Thu Sep 01, 2016 9:44 am
I have noticed another curious thing looking at the photo of the new board. There are a lot of vias on the ground fill -- a standard practice to bring the ground planes on both side of the board together, to avoid noise and to improve thermal conducting. Except there is a no ground fill on the other side -- the vias just hang in the air there:
Not sure if this is a design mistake?
Post by pythoncoder » Thu Sep 01, 2016 1:11 pm
deshipu wrote:...Not sure if this is a design mistake?
Surely: I can't imagine a good reason.
Post by Roberthh » Thu Sep 01, 2016 2:49 pm
For me it looks like the board has more than 2 layers. If you look at the Pins tx, rx, d1, d2, d3, there is a faint shadow of a lower layer at both sides, but no copper on the respective top levels.
mcauser
Post by mcauser » Thu Sep 01, 2016 11:27 pm
I'll post some high res photos once mine arrives
jovijuan
Post by jovijuan » Wed Sep 07, 2016 3:42 pm
Look at the fiducial, TX pin or ceramic antenna. There are for sure mor layers, probably 4.
