Module for Ultrasonic sensor (HC-SR04)
kevinkk525
Re: Module for Ultrasonic sensor (HC-SR04)
Post by kevinkk525 » Wed Jun 05, 2019 8:04 am
As the comment in the code says it outputs meters.
You can use my library for comparison (you have to remove project specific imports and base class first though): https://github.com/kevinkk525/pysmartno ... /hcsr04.py
Kevin Köck
RajaRamesh
Post by RajaRamesh » Wed Jun 05, 2019 4:23 pm
Thank you for sharing the details Kevin. According to my knowledge i updated the code to read distance(removed mqtt, temperature code) and i am confused with below code. can you help me in modifying below code to read distance without temperature.
def _read(self):
        Returns distance in cm.
        Optionally compensated by temperature in °C.
        :return: float
        val = []
        warnings = 0  # probably not going to happen that both warning types occur at the same time
        warning = "minimum distance reached or different problem"
        for _ in range(20):
                pt = self._pulse()
                if pt > 175:  # ~3cm, sensor minimum distance, often read although other problems
                    val.append(pt)
                    warnings += 1
            except OSError as e:
                warning = e
                warnings += 1
            time.sleep_ms(10)
        pt = 0
        for i in range(len(val)):
            pt += val[i]
        pt /= len(val)
        if temp is None:
            dt = (pt / 2) / 29.14
            dt = (pt / 2) * ((331.5 + (0.6 * temp)) / 10000)
        if dt < 0:
            await _log.asyncLog("warn", "Sensor reading <0")
            return None
            dt = round(dt, self._pr)
            dt += self._off
        except Exception as e:
            await _log.asyncLog("error", "Error rounding value {!s}".format(dt))
            return dt
kevinkk525
Post by kevinkk525 » Wed Jun 05, 2019 4:44 pm
Remove all the log instructions and add an optional parameter temp to the function like in my code. (temp=None)
It only corrects with a temperature if it gets one.
I'm currently not at home and only with my phone so can't give you a stripped down version.
Kevin Köck
kevinkk525
Post by kevinkk525 » Wed Jun 05, 2019 4:49 pm
async def _read(self) -> float:
        :return: float
        val = []
        for _ in range(20):
                pt = self._pulse()
                    val.append(pt)
                    warnings += 1
                warning = e
                warnings += 1
            await asyncio.sleep_ms(10)
        if warnings > 10:  # half sensor readings are bad
            print("error", "Too many bad sensor readings, error: {!s}".format(warning))
            return None
        # removing extreme values
        val.remove(max(val))
        val.remove(min(val))
        pt = 0
            pt += val[i]
        pt /= len(val)
        if temp is None:
        if dt < 0:
            print("warn", "Sensor reading <0")
            return None
            dt += self._off
            print("error", "Error rounding value {!s}".format(dt))
            return dt
        return dt
Kevin Köck
RajaRamesh
Post by RajaRamesh » Fri Jun 07, 2019 6:04 am
        :return: float
            dt += self._off
            return dt
        return dt
Thank you Kevin. i will check and get back to you.
RajaRamesh
Post by RajaRamesh » Sat Jun 08, 2019 2:23 pm
Hi Kevin, Now i can see the distance in cm. But, first it is display's error in rounding value. why is it happening?
dt += self._off
return dt
Distance in cm.jpg (28.29 KiB) Viewed 5479 times
kevinkk525
Post by kevinkk525 » Sat Jun 08, 2019 2:27 pm
I guess self._pr isn't defined. you can replace it with 2
self._offs should be 0
Kevin Köck
RajaRamesh
Post by RajaRamesh » Sat Jun 08, 2019 2:52 pm
Thank you Kevin for your help.
