Ethernet board
logicaprogrammabile
Ethernet board
Post by logicaprogrammabile » Tue Sep 27, 2016 8:58 am
hi all
i need to know how to connect a ethernet module to the pyboard.
the ethernet class which devices supports? it is possible connect the enc28j60 to the spi port and use the standard ethernet class?
thanks
Marco
Re: Ethernet board
Post by pythoncoder » Tue Sep 27, 2016 3:50 pm
The Wiznet 5K series is officially supported https://github.com/micropython/micropyt ... /README.md.
logicaprogrammabile
Re: Ethernet board
Post by logicaprogrammabile » Tue Sep 27, 2016 4:23 pm
thanks!
to use the wiz5k it is correct to connect this module to the spi port?
Re: Ethernet board
Post by pythoncoder » Wed Sep 28, 2016 4:38 pm
Glancing at the source code it looks that way, but I've never actually used the device. You need to use the network build of firmware.
