Ethernet Adapter for PyBoard Which?
amano001
Post by amano001 » Wed Oct 12, 2016 4:55 pm
I am looking to add ethernet to my pyboard but not 100% sure which is the best compatible wise. It shows in the docs Wiznet 5200/5500 based chips.
I was wondering if this one would work fine?
WIZ550IO from digikey
http://www.digikey.com/product-detail/e ... ND/4425703
There was also this one
WIZnet W5100 Network Module with Mag Jack - WIZ811MJ from sparkfun
https://www.sparkfun.com/products/9473
Thanks!
Re: Ethernet Adapter for PyBoard Which?
Post by dhylands » Wed Oct 12, 2016 5:15 pm
I think that only the 5100 is currently supported.
amano001
Post by amano001 » Wed Oct 12, 2016 8:42 pm
Hmmm alright is there any where to confirm for sure, didnt want to waste $50 haha then have issues getting it running. I see in the docs it just says this :
This class allows you to control WIZnet5x00 Ethernet adaptors based on the W5200 and W5500 chipsets (only W5200 tested).
Thanks again.
Post by dhylands » Wed Oct 12, 2016 8:51 pm
Sorry - it looks like 5200 (not 5100) is what's supported.
https://github.com/micropython/micropyt ... conf.h#L59
I started playing with the 5500, since I have a dev board with the 5500 on it, but it didn't seem to be as simple as changing the 5200 to 5500. Someday, I'll get back to it.
amano001
Post by amano001 » Wed Oct 12, 2016 9:03 pm
Thanks very much! Any idea where I can buy a 5200 adapter or a variant ? cant seem to find any available on digi or sparkfun.
Scratch that I found it on digikey there search is so convoluted its impossible to find things sometimes.
tehfink
Post by tehfink » Mon Oct 24, 2016 8:41 am
amano001 wrote:Thanks very much! Any idea where I can buy a 5200 adapter or a variant ? cant seem to find any available on digi or sparkfun.
Which board did you end up buying? And how did the connection & driver support go?
HansvL
Post by HansvL » Mon Oct 24, 2016 7:27 pm
FWIW, I've hooked up a WIZ820IO to my PyBoard without any issues.
It has magnetics included.
Got it from TME for € 22,00 earlier this year.
tehfink
Post by tehfink » Tue Oct 25, 2016 10:49 am
HansvL wrote:FWIW, I've hooked up a WIZ820IO to my PyBoard without any issues.
Cool, thanks for the reply. Any thoughts on ease of hookup, stability, and dependability?
HansvL
Post by HansvL » Tue Oct 25, 2016 7:08 pm
Well, I installed the proper firmware and followed the examples for the network module. Mine is hooked up as
nic = network.WIZNET5K(pyb.SPI(1), pyb.Pin.board.X5, pyb.Pin.board.X4)
My PyBoard reads several sensors and uses a simple http GET to post data to my server, 10 times per hour. It has been doing that non-stop since mid May and hasn't missed a beat. I intend to implement a watchdog timer but so far the board hasn't failed. So for my (hobby) purpose, it is quite stable enough.
Not sure what you mean by dependability.
raijovj
Post by raijovj » Mon Aug 14, 2017 6:57 am
dhylands wrote:Sorry - it looks like 5200 (not 5100) is what's supported.
Yep, w5500 is not working. Did you made any progress? :D
