Set the correct Date at creating a nwe File Document
diego.cuba
Post by diego.cuba » Fri Nov 25, 2016 3:09 pm
Hi Group,
I would like to know how is possible set the correct date when i create a new file , in order to store values that i'm sensing with a sensor.
archivo=open('/sd/archivo.txt','w')
archivo.write('{},{},{},{},{},{},{}\n'.format(t,xm,ym,zm,xg,yg,zg))
Which part of the code must I have set the time or date characteristic?
Is it possible to preserve on memory the correct time?, and the next time i rund code ,it sets the correct datetime?
((( :geek: Diego Cuba Z )))
platforma
Re: Set the correct Date at creating a nwe File Document
Post by platforma » Fri Nov 25, 2016 4:48 pm
Perhaps the RTC module will be of help: http://docs.micropython.org/en/latest/p ... C.datetime
Post by dhylands » Fri Nov 25, 2016 5:59 pm
And in order to preserve the RTC date/time across power cycles, you'll need to add a small coin cell battery. Typically a CR2032.
On the original pyboard (V1.0) connect the + side of the battery to the VBAT, and the - side to GND. On the newer pyboards (V1.1) use the VBACK and GND pins (VBAT on the newer boards refers to a battery for powering the board).
