OSError: scan failed
jamesb
Post by jamesb » Sun Dec 18, 2016 3:00 am
wifi.scan() gives:
>>> interface.scan()
I think it's when it can't see any wifi networks. I guess I'll enclose it in a try-except block, unless someone know a smart way around this?
eradicatore
Re: OSError: scan failed
Post by eradicatore » Tue Oct 03, 2017 7:59 pm
Were you able to confirm this happens if the scan results in no networks found? I was hitting OS error on scans in one location last night very repeatedly, so I would assume you're right. But I just expected the documentation to also mention this pretty interesting way of reporting nothing found (rather than just an empty tuple).
eradicatore
Post by eradicatore » Thu Nov 16, 2017 8:21 pm
I still can't get the try/except to work around this failure when there are no wifi scan results. Does anyone else see this failure if there are zero ap's visible when you try to scan? Why would code like this not work?
        scan_results = wifi.scan()
    except:
        ## for some odd reason OSERROR here means no wifi APs found
        scan_results = None
Post by pythoncoder » Fri Nov 17, 2017 11:17 am
Hmm. That's a hard one to test unless you live in Greenland ;) My Faraday cage (AKA microwave oven) is too small for my laptop. Ideas anyone?
stundenblume
Post by stundenblume » Thu Jan 10, 2019 7:55 pm
I know, this is very old but yes, I have the same Problem.
Post by Roberthh » Thu Jan 10, 2019 8:31 pm
For me it works. I made a little test script:
from network import WLAN
wlan=WLAN()
        print(wlan.scan())
    except OSError:
        print("Silence")
Firmware: MicroPython v1.9.4-773-gafecc124-dirty on 2019-01-04; ESP module with ESP8266
I placed the ESP8266 in the microwave (thanks Peter), with the thinnest cable I could find, and got both scan results and 'Silence' printed. I must say that WiFi reception in our kitchen is poor, and the rssi, when received, was below -90 dB.
B.t.w.: Poor WiFi in the kitchen is not that bad for personal communication at the table.
stundenblume
Post by stundenblume » Tue Jan 15, 2019 7:20 am
Hello Robert,
thanks for testing. I will try it again, as I was testing I was in a train, right now I can't find a place without wifi signals.
Sebastian
