WiPy v1.8.7 ( JAn&Feb) - SD reading issue
federico
Post by federico » Tue Feb 07, 2017 11:48 pm
The new firmware does not permit the SD reading.
From telnet REPL typing :
>>>os.listdir('/sd')
we have .......
OSError: 19
Consequently I have reinstalled the previous firmware v1.8.6 and all is OK because typing
the previous command I have a list of SD content.
The problem is on mcuimg.bin file ( I suppose)
Regards
kfricke
Re: WiPy v1.8.7 ( JAn&Feb) - SD reading issue
Post by kfricke » Wed Feb 08, 2017 8:20 am
The was a change regarding the used FAT library and filesystem mount points. The maintainers should be aware of this but you can also file an issue on github.
federico
Post by federico » Sat Feb 11, 2017 11:20 pm
Only to thank you and Dr.Damien George for the solution of the SD issue - with firmware MicroPython v1.8.7-213- gaac2db9 on 2017-02-11;WiPy with CC3200
Regards
Federico MONALDI
