Memory allocation and deallocation
First of all I would like to say that I find your work amazing. Bringing the Python language to this standard is really beautiful - I can finally use its embeddable properties as a replacement for Lua - with better syntax (generators look way better) and better language support (exceptions are just great).
I started by developing a small module in c as an extension and I still haven't figured out how the gc finds "abandoned" memory.
I've read the wiki page regarding the gc and still it's a mystery for me.
Question 1.
If I create my own type with a "new" function.
In that function I allocate, using m_new some memory, and return it from the function. Now I understand that now the object is referenced by the python vm - and when references no longer exist - the gc will be able to clean that piece of memory.
But assuming my object has a pointer field to an array of ints I want to allocate dynamically using the same python heap in my "new" function - how does the gc knows to connect between the outer object seen by the vm and my inner implementation?
At first I thought I should implement a specific __del__ function for my type - but __del__ doesn't even get called!
Question 2.
What happens if an exception is thrown in my c code using nlr magic after I allocated some memory using m_new but haven't returned it yet?
Question 3.
Connected to question 2 - in objstr.c we have:
STATIC mp_obj_t str_encode(size_t n_args, const mp_obj_t *args) {
mp_obj_t new_args[2];
if (n_args == 1) {
new_args[0] = args[0];
new_args[1] = MP_OBJ_NEW_QSTR(MP_QSTR_utf_hyphen_8);
args = new_args;
n_args++;
return bytes_make_new(NULL, n_args, 0, args);
1. New qstr - heap allocation?
2. New bytes - heap allocation?
What happens if second one fail? nlr magic? What happens to memory allocated first?
(Nothing special about objstr.c just tried to find two allocations without checks in between)
Thanks!
Sam
Question 1.
Question 2.
Question 3.
if (n_args == 1) {
args = new_args;
n_args++;
Thanks!
Sam
Re: Memory allocation and deallocation
The way that the GC (garbage collector) works is that any object which has a pointer to it is kept.
MicroPython has the notion of root pointers. These are maintained in the mp_state_t struct:
https://github.com/micropython/micropyt ... #L100-L169
Any object which is pointed to through a root pointer, or another object, or a pointer on the stack or from one of the registers will be kept. Other objects will be freed.
So if you allocate something and then throw an exception, the first allocated object will generally wind up being freed (at garbage collection time), unless a pointer to it was ultimately stored in a root pointer or other python object.
QSTR's are otherwise known as "interned" strings. These are referenced by index and not by pointer, which allows some performance improvements. Once a QSTR is allocated it never gets freed. There is a pool of them. QSTRs are also only allocated once. If a QSTR already exists, then the index of it will be returned rather than allocating a new one.
Thanks for the explanation, but I still haven't gotten my answer.
If I return my own object, from a type I created using m_new on 10 bytes from a c function to the vm. But in my own object the first 4 bytes (32 bit machine) is an internal pointer in the struct that points to another memory, let's say 4 bytes that were allocated by m_new too - to hold a dynamic int.
When my own object gets GC'd - how can the GC possibly know about my 4 internally allocated bytes, shouldn't it leak? Isn't a some kind of a destructor needed for my object?
Thanks,
Sam
Thanks,
Sam
The GC will examine all of the objects and follow any pointers contained within them.
For example, here's a C strcuture for the UART:https://github.com/micropython/micropyt ... .c#L78-L92 which contains a pointer to read buffer (line 91).
A side effect of this is that the GC will scan the UART object and see the pointer and thus not free it. The way the gc works, if the object contains a bit pattern which looks like a heap pointer, it might accidentally not free an object which should otherwise be freed.
When the UART object gets GC'd, then there will no longer be a pointer to the read_buf (assuming that there isn't one someplace else), so it will in turn be GC'd.
Interesting, so let's see if I got it right:
1. If the heap contains a pointer to the heap - the GC will treat it as a referenced memory. (It must be aligned?)
2. The GC has to scan all bytes in the heap to clean internally referenced memory
3. If, god forbid, my internal pointer will not be aligned - the memory it points too will eventually be GC'd? Making it point to garbage.
4. The pattern is something like pointer size in heap range with a certain suffix? (Depending on block size?)
5. If I have a large array of ints on the heap which never gets freed and by 'accident' these ints are following the pattern of the heap - memory will not be GC'd?
6. Finally, if objects have internal state - the correct way to use them is with a ".close()" function like in sockets
Thanks,
Sam
Thanks,
Sam
Small integers are constrained such that b31==b30. This enables uPython to reliably distinguish between a small integer and a pointer which is guaranteed not to follow this pattern. This is possible because pointers are word aligned, so have two 'spare' bits. It's binary blobs like bytes instances which can (rarely) be mistaken for pointers and needlessly retained.
Pointers created by uPython will always be word aligned. I guess you could create a non-aligned pointer in C or inline assembler but making this visible to uPython is probably a bad idea.
If an object has internal state its RAM will be reclaimed when the last pointer to the object goes out of scope. There is usually no need to code explicit closure.
I see,
It's a shame that there is no clear/thouroughful documentation regarding this matter - feels like it's one of the basics in case one wants to contribute.
In any case, big thanks for the explanations!
Sam
Sam
There's clear and thorough documentation, it's in the usual places - Wikipedia, Google, source code. Google gives about 2 million hits for "garbage collection memory". Sad conclusion one may come to is that if those 2 million pages didn't help, 2 million first won't help eitherIt's a shame that there is no clear/thouroughful documentation regarding this matter
Awesome MicroPython list
- elliotwoods
Oh this is really interesting.
I'm having issues here with my allocated memory becoming invalid after garbage collection.
I have code classes in C++ being exported across to C
I have read up on garbage collection before, but I'm unaware of the strategy of scanning the heap for pointers.
It seems strange that such a strategy would be safe at all (I presume it is, but I'm just not getting something)
e.g. if you have an array of uint32_t's
then ok.. maybe they are not aligned the same way as pointers, but the MSBs from one element with the LSBs of the next element will mix to look like a valid pointer.
How can such a situation be avoided?
This maybe isn't my issue, I'm just curious
My actual issue is that objects within my C++ code are being invalidated by the garbage collector
Currently investigating but I might reach out for help.
- elliotwoods
Ok here's where I'm at:
tensorflow asks for a chunk of memory that it can use:
It then uses this memory to store everything (both the model and the variables)
On garbage collection, this pointer is generally invalidated.
So now I'm using:
And I also copy that pointer into the struct which represents the model in the micropython module.
Now this memory is not invalidated as a whole, but some parts of the memory inside are now corrupted.
I presume this is because there are pointers inside that block of allocated memory which get either moved or deleted by the garbage collector.
Is it possible for the garbage collector to simply ignore a section of memory altogether?
thank you
const int tensor_arena_size = 2 * 1024;
uint8_t tensor_arena[tensor_arena_size];
So now I'm using:
this->heapArea = m_malloc(tensorArenaSize + alignment);
this->tensorArena = (uint8_t*) MP_ALIGN(this->heapArea, alignment);
thank you
