Zip File Extractor
- SureshVakati
Zip File Extractor
Are there any libraries available to extract '.ZIP' or '.RAR' files in SD card?
Re: Zip File Extractor
That's a "no", but there is one for TAR files: https://github.com/micropython/micropyt ... r/utarfile
The decompressor for zipfile is available. So if you're up to parsing the zip file format, then you could write one in pure python.
I've got C code that was never merged that does pieces of it on MicroPython. Frozen files wound up being more useful.
- SureshVakati
Hello Dave,
Are you talking about uzlib module or gzip module? Can I pass a file name as argument to uzlib.decompress(data)?
uzlib is what zip uses. No it doesn't take a filename. You'd need to parse the zip file format and extract the compressed data and feed that into zlib.decompress.
Hello All, following up on this as I am trying to do the same (extract contents of a zip). Forgive my noobness but is this thread saying that you can somehow use uzlib to decompress a .zip file? I have a Digi Xbee 3 running micropython v.1.12. and have a .zip file with three files in it (certificates with the file extension .pem).
Went here but this is all C code?
https://github.com/pfalcon/uzlib
Tried using this in my project but it's evidently not complete/working.
https://pypi.org/project/micropython-cpython-uzlib/
Any suggestions?
Any suggestions?
uzlib only knows about the compression format used to compress a file inside a zip file. It doesn't know how to read a zip file though.
So you need to write some code to parse the ZIP file headers and such and get to the compressed data for a file. Once you've got that compressed data you can use uzlib to decompress that data.
Thanks for the reply dhylands. That's a few steps ahead of where I'm actually stuck. Just getting the uzlib module to be recognized seems to be a problem. uzlib.py from https://pypi.org/project/micropython-cpython-uzlib/ only contains the below. The other problem is that "zlib" from the import statement isn't on my micropython implementation (https://github.com/digidotcom/xbee-micropython).
import micropython
from zlib import *
class DecompIO:
def __init__(self, stream, dict_bits):
self.stream = stream
self.decomp = decompressobj(dict_bits)
self.pending = b""
def read(self, size):
while len(self.pending) < size:
inp = self.stream.read(256)
if not inp:
break
outp = self.decomp.decompress(inp)
self.pending += outp
outp = self.pending[:size]
self.pending = self.pending[size:]
return outp
