How to obtain a list of importable modules?
pagano.paganino
Re: How to obtain a list of importable modules?
Post by pagano.paganino » Thu Nov 09, 2017 2:56 pm
Hi Lisa,
i haven't esp32, on pyboard a trick can be:
import io
import os
class DUP(object):
    def __init__(self, s):
        self.s = s
    def write(self, data):
        self.s += data
        return len(data)
    def readinto(self, data):
        return 0
s = bytearray()
os.dupterm(DUP(s))
help('modules')
os.dupterm(None)
into 's' you can see the output from help('modules')
LisaM
Post by LisaM » Thu Nov 09, 2017 3:10 pm
AttributeError: 'module' object has no attribute 'dupterm'
Post by pythoncoder » Thu Nov 09, 2017 6:17 pm
@pagano.paganino Ingenious!
@LisaM I think dupterm is yet to be implemented on ESP32.
LisaM
Post by LisaM » Fri Nov 10, 2017 12:29 am
Running on pyboard:
File "test.py", line 17, in <module>
ValueError: need a UART object
test.py:
import io
import os
class DUP(object):
        self.s = s
        self.s += data
        return len(data)
        return 0
s = bytearray()
os.dupterm(DUP(s))
help('modules')
os.dupterm(None)
print(s)
Line 17: os.dupterm(DUP(s))
So... not working on pyboard either...
Post by Roberthh » Fri Nov 10, 2017 6:34 am
You might need to update. It works on my PyBoard:
(sysname='pyboard', nodename='pyboard', release='1.9.3', version='v1.9.3-11-gb9580b8-dirty on 2017-11-07', machine='PYBv1.1 with STM32F405RG')
LisaM
Post by LisaM » Fri Nov 10, 2017 11:02 am
MicroPython v1.9.2-173-g829c329-dirty on 2017-10-20; PYBv1.0 with STM32F405RG
Hmmm, little bit difference. I was going to update anyway, due to #3379. I'll test it after the update.
It also need to work on all of my testbeds, being : Orange PI Zero, ESP32, NodeMCU, Pyboard.
For now i solved it by using the __init__.py file (in the plugins dir) to write down which plugins are available in the (frozen!) plugins dir.
Thx!
Edit: Tested with new release and there it works!
upymar
Post by upymar » Fri Jun 15, 2018 12:29 pm
How do I get a list of available functions of a specific module?
In another thread I read something about e.g. the ntptime module but didn't find anything in the documentation.
So where do I get the information how to use modules and their functions which are not mentioned in the documentation?
Thanks and best regards
Post by pythoncoder » Sat Jun 16, 2018 6:52 am
ntptime is not included on the Pyboard by default as it has no network connection, but it can be found on the ESP8266.
help('modules')
provides a list of compiled-in modules. This list does not include modules you might have put in the device's filesystem.
import ntptime
dir(ntptime)
will list its methods. Or you can look at the code in the source tree.
Ideally all these modules would be documented but sometimes, unfortunately, you do have to track down the code and take a look.
DUP class above
Post by pythoncoder » Sun Jul 08, 2018 6:34 am
For anyone wanting to use the DUP class, in this forum thread @Damien said:
There was a recent change to how this stuff works behind the scenes and you now need to derive the DUP class from io.IOBase: class DUP(io.IOBase)
HermannSW
Post by HermannSW » Sat Oct 20, 2018 1:02 pm
help('modules')
Interesting, I compared my ESP01s
MicroPython v1.9.4-272-g46091b8a on 2018-07-18; ESP module with ESP8266
and ESP32
MicroPython v1.9.4-623-g34af10d2e on 2018-10-03; ESP32 module with ESP32
Micropython modules (by "$ cat | for w in `cat`; do echo $w; done | sort > esp__.txt" and copy&paste).
There are 3 modules that only exist on ESP8266, and 10 modules that only exists on ESP32:
$ diff --side-by-side -W 35 esp8266.txt esp32.txt
apa102	      |	apa106
array		array
binascii	binascii
_boot		_boot
btree		btree
builtins	builtins
	      >	cmath
collections	collections
dht		dht
ds18x20		ds18x20
errno		errno
esp		esp
	      >	esp32
flashbdev	flashbdev
framebuf	framebuf
gc		gc
hashlib		hashlib
	      >	heapq
inisetup	inisetup
io		io
json		json
lwip	      <
machine		machine
__main__	__main__
math		math
micropython	micropython
neopixel	neopixel
network		network
ntptime		ntptime
onewire		onewire
_onewire	_onewire
os		os
port_diag     <
random		random
re		re
select		select
socket		socket
ssl		ssl
struct		struct
sys		sys
	      >	_thread
time		time
ubinascii	ubinascii
ucollections	ucollections
ucryptolib	ucryptolib
uctypes		uctypes
uerrno		uerrno
uhashlib	uhashlib
	      >	uhashlib
uheapq		uheapq
uio		uio
ujson		ujson
	      >	umqtt/robust
	      >	umqtt/simple
uos		uos
upip		upip
upip_utarfile	upip_utarfile
	      >	upysh
urandom		urandom
ure		ure
	      >	urequests
uselect		uselect
usocket		usocket
ussl		ussl
ustruct		ustruct
utime		utime
utimeq		utimeq
uzlib		uzlib
webrepl		webrepl
_webrepl	_webrepl
webrepl_setup	webrepl_setup
websocket	websocket
websocket_hel	websocket_hel
zlib		zlib
I went a step further and wanted to compare the common module features between both MicroPythons:
$ comm -12 esp8266.txt esp32.txt > common.mod
With webrepl_client.py "-r" option and input redirect this was easy to do (I did reconnect to esp8266 Wlan after the first command was executed while connected to ESP32 Wlan):
$ webrepl_client.py -p abcd -r 192.168.4.1 < <(sleep 1 && for m in `cat common.mod`;  do echo -e "help(\"$m\")"; done; echo "exit") > esp32.detail
$ webrepl_client.py -p abcd -r 192.168.4.1 < <(sleep 1 && for m in `cat common.mod`;  do echo -e "help(\"$m\")"; done; echo "exit") > esp8266.detail
First I converted to Unix format. The diffs.txt file is attached:
$ dos2unix esp32.detail esp8266.detail
dos2unix: converting file esp32.detail to Unix format ...
dos2unix: converting file esp8266.detail to Unix format ...
$ diff --side-by-side -W 60 esp8266.detail esp32.detail > diffs.txt
There is no feature that does exist on esp8266 Micorpython only, but there are 248 in the 62 common modules that exist on esp32 only:
$ diff --side-by-side esp8266.detail esp32.detail | grep "  <"
$ diff --side-by-side esp8266.detail esp32.detail | grep "  >" | wc --lines
248
But there are only 4 different features:
$ grep "  >" diffs.txt  | sort -u
			     >	  center -- <function>
			     >	  partition -- <function>
			     >	  rpartition -- <function>
			     >	  splitlines -- <function>
P.S:
Ooops -- I will redo the evaluation, eg. for module utime I did
help('utime')
which is wrong, instead this is needed:
import utime
help(utime)
diffs.zip
contains diffs.txt
(2.03 KiB) Downloaded 7 times
