Esp32 make is not working
input
Post by input » Sun Apr 23, 2017 9:56 am
I have a problem with building the firmware with make -C mpy-cross.
I get an error with: Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity
I follow this tutorial: https://github.com/micropython/micropyt ... sp32/esp32
What I am doing wrong.
Re: Esp32 make is not working
Post by Roberthh » Sun Apr 23, 2017 2:04 pm
is not an error message. Better go into the mpy-cross directory and run:
make
input
Post by input » Sun Apr 23, 2017 2:16 pm
I also tried that but then I get the same warning.
input
Post by input » Sun Apr 23, 2017 3:50 pm
Thanks. But into the mpy-cross dir with make I get the same error
Post by dhylands » Sun Apr 23, 2017 5:56 pm
That's not an error. If that's the only thing you see then it means everything is up-to-date.
If you really want to see it build then do:
make clean
make
The message about using V=1 is printed everytime you run make.
input
Post by input » Sun Apr 23, 2017 6:09 pm
Thanks for the reply
Now it is compiling.
Post by pythoncoder » Mon Apr 24, 2017 7:05 am
@input I suspect you're unfamiliar with make. It only compiles a file if the source file is newer than the object file (the file output by the compiler). This saves a lot of time in development: you edit one file in a big project and make ensures that file alone gets compiled.
So, if everything is up to date, make just verifies that fact and terminates. It issues the message you see every time it runs, whether or not it has to compile any files. As others have said, it's not an error message: it's what you expect to see when everything is up to date.
make clean forces it to recompile everything by deleting all the object files. It's not usually necessary but it's a useful trick if you suspect something has gone wrong with the build phase.
Turbinenreiter
Post by Turbinenreiter » Mon Apr 24, 2017 10:48 am
make -B
also forces a rebuild.
