Can't get the servo SG90 working
Lornioiz
Post by Lornioiz » Wed May 03, 2017 11:05 am
Hi all,
I dismantled a (working) SG90 servo from an old Arduino project and I tried to test it with Micropython.
With the code provided in the website I was not able to make it work.
Once I write these lines:
servo = PWM(Pin(14), freq=50, duty=77)
servo.duty(30)
servo.duty(122)
The servo moves very quickly for an instant, then stand still while making a buzzing noise as it is somehow stuck.
I thought the problem in the current, so I attached the servo to an external 5v power source (I tried 3.3v as well with the same results) but it didn't solve the problem.
Tried it with both an Wemos D1 mini and an Amica mcu.
Un fortunately I have only one servo as of now, but as I said, it is working fine with Arduino.
Any idea why it is now working?
Thanks!
P.S.
I treid the same with Servo library but it still doesn't work.
Re: Can't get the servo SG90 working
Post by deshipu » Wed May 03, 2017 7:43 pm
Try different values. You are probably trying to move the servo outside of its valid range, which is why it's buzzing.
Post by pythoncoder » Fri May 05, 2017 8:36 am
Indeed. The duty values of 30 and 122 look wrong to me. See https://en.wikipedia.org/wiki/Servo_control. The range is 1-2ms out of a 20ms period - this corresponds to something like 50-100 relative to the 1023 full scale. Exact values depend on the servo - some experimentation is called for.
Lornioiz
Post by Lornioiz » Thu May 11, 2017 9:11 am
Thank you all, that was the problem indeed. As I said, first time with servos.
I'm now using the great servo D1 mini shield from Deshipu... I'm now looking for a simple idea that can make use of a bunch of servos! ;)
Post by deshipu » Thu May 11, 2017 3:19 pm
How about something like this?
Post by pythoncoder » Fri May 12, 2017 7:08 am
Try looking here viewforum.php?f=5 - you'll find quite a few things people have built.
Zolee
Post by Zolee » Thu Sep 28, 2017 5:30 pm
It is possible to control the servo speed with wemos d1 mini?
Zolee
Post by Zolee » Sun Oct 01, 2017 6:14 pm
I have written a simple function to control the servo speed, but not work in parallel. (multiprocessing)
speed = ['0.5','1']
servo = {'1a':'5','1b':'4'}
def motor_vezerles(servok, new_state, sebessegek):
    sebesseg=float(speed[sebessegek])
    pinnumber=int(servo[servok])
    last_state=PWM(Pin(pinnumber), freq=50)
    last_state=last_state.duty()
    if last_state<new_state:
        lepesek=new_state-last_state
        min_ido=lepesek*4
        if sebesseg!='1':
            osszido=min_ido/sebesseg
            osszido=osszido-min_ido
            milisec=round(osszido/lepesek)
            milisec=0
        for x in range(last_state+1, new_state+1):
            PWM(Pin(pinnumber), freq=50, duty=x)
            time.sleep_ms(milisec)
        lepesek=last_state-new_state
        min_ido=lepesek*4
        if sebesseg!='1':
            milisec=0
        for x in range(last_state-1, new_state-1, -1):
Post by pythoncoder » Mon Oct 02, 2017 5:40 am
This is probably a good use-case for the uasyncio library. If you're unfamiliar with asyncio, there is an unofficial tutorial here https://github.com/peterhinch/micropython-async - follow the link to tutorial.
