picoweb URL Params in routes
devnull
Post by devnull » Sun Oct 15, 2017 5:55 am
Hi;
I am unable to successfully define a regex to handle url GET parameters such ads:
http://mydevice/?x=1&y=2&z=3
def json(req,resp):
  yield from picoweb.jsonify(resp,{"error":True})
ROUTES = [
  (re.compile("^/\?.*"), json),
  ("/", lambda req, resp: (yield from app.sendfile(resp, path+"index.htm"))),
  (re.compile("^/(.+)"), lambda req, resp: (yield from app.sendfile(resp, path + req.url_match.group(1)))),
I have attempted to look for the path starting with "/?" - what am I doing wrong ??
devnull
Re: picoweb URL Params in routes
Post by devnull » Sun Oct 15, 2017 7:23 am
OK, I found the reason, the queryParams are already stripped from the url and are available from req.qs
def json(req,res):
  dict = {x[0] : x[1] for x in [x.split("=") for x in req.qs[1:].split("&") ]}
  print(dict);
  yield from picoweb.jsonify(res,dict)
davlefou
Post by davlefou » Mon Jan 28, 2019 3:19 pm
Hi, you have made an mistake, it start with 0:
[code]
[/code]
