Driver for WS2812 RGB LEDs (NeoPixels, ...)
Architekt
Post by Architekt » Fri Nov 07, 2014 9:27 am
Hi, I made driver for WS2812 (and compatible) RGB LEDs. Those are popular RGB LEDs used for example in AdaFruit NeoPixels.
Driver: https://github.com/JanBednarik/micropython-ws2812
MicroPython and NeoPixels ring demo: http://youtu.be/ADYxiG40UJ0
fma
Re: Driver for WS2812 RGB LEDs (NeoPixels, ...)
Post by fma » Mon Nov 10, 2014 1:15 pm
Nice! I'll give it a try...
Thanks for sharing!
Frédéric
Architekt
Post by Architekt » Sun Nov 23, 2014 6:30 pm
I have played with 4 meters of NeoPixels Strip which has 240 RGB LEDs in total.
Driver works fine. I just released v1.1 with some speed optimizations. Should work for much more RGB LEDs :)
In action: http://youtu.be/vb5l3h1-TqA
240 RGB LEDs driven by MicroPython
NeoPixels strip - small 2.jpg (124.57 KiB) Viewed 54115 times
fma
Post by fma » Sun Nov 23, 2014 7:03 pm
Excellent!
Frédéric
LarryTru
Post by LarryTru » Tue Nov 25, 2014 4:37 pm
Thanks for the effort! :)
Larry
Damien
Site Admin
Post by Damien » Mon Dec 08, 2014 9:41 pm
DMA transfers are now supported by the SPI bus, so you should no longer need to disable interrupts while doing the spi.send call.
Architekt
Post by Architekt » Wed Dec 10, 2014 10:51 am
Damien wrote:DMA transfers are now supported by the SPI bus, so you should no longer need to disable interrupts while doing the spi.send call.
Thank's for info. I have updated the driver.
fma
Post by fma » Wed Dec 10, 2014 11:14 am
So, DMA usage is totally transparent?
Frédéric
Damien
Site Admin
Post by Damien » Wed Dec 10, 2014 6:19 pm
fma wrote:So, DMA usage is totally transparent?
Yes. If interrupts are enabled it uses DMA, otherwise it uses polling.
fma
Post by fma » Wed Dec 10, 2014 6:50 pm
Great! But as I understand from your post on the other thread, the call to send() is still blocking during transfert, so CPU is not availabe for other tasks. Am I right?
Frédéric
