Compile error on Android Armv7l with Clang
SpotlightKid
Re: Compile error on Android Armv7l with Clang
Post by SpotlightKid » Fri Nov 17, 2017 7:36 pm
Unfortunately, it's not so easy.
Two of the functions in "py/nlrthumb.c" with inline assembler have C statements, which are apparently there just to placate GCC. I tried guarding them with
#if defined(__GNUC__)  && !defined(__clang__)
but the function "nlr_thumb" also has more C statements at the beginning, which actually do something.
Also, I tried the fix suggested by jiggster to add
#define MICROPY_NLR_SETJMP 1
to "py/nlr.h", but that only unearthed another Clang incompatibility in "py/asmarm.c" (see the error message I put in my post on the Raspberry Pi above).
My knowledge of what's going on there is not enough to suggest a sensible fix.
OTOH, I found some unofficial packages to install GCC 6 for armv7 in my Termux environment on my Android phone, so now I'm able to compile MicroPython there. But I might still bring up the Clang incompatibility issues on Github.
stijn
Post by stijn » Sat Nov 18, 2017 9:59 am
Sorry I missed that part about the other asm statements; the assembly written is likely some gcc dialect. However you don't really need asmarm.c to get a working executable: #define MICROPY_EMIT_ARM (0) in your mpconfigport.h and it will skip what's in asmarm.c
SpotlightKid
Post by SpotlightKid » Sat Nov 18, 2017 11:00 am
@stijn @jickster: thanks for the tips!
stijn
Post by stijn » Sun Nov 19, 2017 2:20 pm
I tried to build MicroPython on a Raspberry Pi 3 here
>> uname -a
Linux rpi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
>> clang --version
Raspbian clang version 3.5.0-10+rpi1 (tags/RELEASE_350/final) (based on LLVM 3.5.0)
Target: arm-unknown-linux-gnueabihf
Thread model: posix
and that sort of works: as said it needs #define MICROPY_EMIT_ARM (0) in the mpconfigport.h, and then there was still this:
gccollect.c:116:14: error: variable 'r4' is uninitialized when used here [-Werror,-Wuninitialized]
    arr[0] = r4;
Not a good sign but after removing -Wuninitialized everything builds but the resulting executable segfaults when gc kicks in which I sort of expected: I assume the assembly used is written for gcc/non-arm or so and is not entirely correct for use with clang/arm. Using the stjmp based version (#define MICROPY_NLR_SETJMP (1) in mpconfigport.h) does produce a working version though and all tests pass.
So since you stated interest in fixing MicroPython so it compiles out of the box with clang I'd suggest a PR which figures out if clang is used (on arm, I guess, never tried on linux) and if so uses the 2 defines above in linux/mpconfigport.h. The alternative is fixing the assembly used (for the NLR stuff that might not be too hard, possibly just needs different registers to be used).
SpotlightKid
Post by SpotlightKid » Sun Nov 19, 2017 2:49 pm
Version 3.5 of Clang doesn't produce an error, when a naked function with inline asm contains C code. That was only explicitly forbidden later.
I booted Arch Linux ARM on my Raspberry Pi 3 - the Rapsi 2 version for armv7 architecture - so I could use Clang 5.
